Introduction: DIY GoPro Dome Housing
A DIY GoPro Dome you can make for free without any tools and is able to capture stunning over-under shots!
The purpose of a commercial GoPro dome housing is to seperate water from the GoPro itself. This allows for easy 50/50 or over-under shots as you have more room to accurately compose photographs. This practically free alternative does just that!
Step 1: Materials
All you need is:
- Original GoPro packaging
- Base Plate
- GoPro
- Rubber Bands
- Wrist strap (optional)
- Base Plate
- GoPro
- Rubber Bands
Step 2: Wash Up
Simply remove your "dome" from the box and gently wash it removing all marks and sticky sections. Be careful not to scratch it!
Step 3: Assemble
Set you GoPro to "Wide View" and mount it on the base plate using the quick release buckle and screw. Place your clear plastic "dome" upside down and use elastic bands to secure the base plate to it.
The reason it upside down is because the clear plastic section is extremely waterproof while there is no proper seal on top where the base plate is joined. That is why it is extremely important to always still use a waterproof GoPro housing and NOT a skeleton.
OPTIONAL: Using a strap (or elastic bands), feed it through the hole in the "dome" so you can be tethered to the camera.
Step 4: Capture
Go out into the water and start photographing and filming! Use a Wifi remote or "Video + Photo" mode.
For another great mount, Check out this awesome Instructable:
https://www.instructables.com/id/Versatile-GoPro-Clip
