Introduction: DIY, HAND ROUTER,OLD LADY,S TOOTH
WHAT YOU WILL NEED
DRILL
SHARP CHISEL
HAMMER,MALLET
6 INCH LONG BY, 2X1 INCH PIECE OF WOOD
AND A COUPLE OF CLAMPS
Step 1: CLAMP YOUR WOOD
THIS IS A QUICK AND EASY TO MAKE INSTRUCTABLE
AND IF DONE PROPERLY WILL GIVE YOU GREAT RESULTS.
SO, CLAMP YOUR BIT OF WOOD TO YOUR WORK AREA
Step 2: DRILL AT a 45 DEGREE ANGLE
NOW WITH YOUR DRILL.
DRILL FROM THE FACES EDGE NEAREST TO YOU
AT A 45 DEGREE ANGLE
START DRILLING .
YOU CAN GO STRAIGHT THROUGH OR STOP AT 3/4.
Step 3: GRAB a CHISEL SLIGHTLY WIDER THAN THE DRILL HOLE
NOW,
GRAB A GOOD SHARP CHISEL
AND HAMMER THE CHISEL THATS SLIGHTLY WIDER THAN YOUR DRILL HOLE.
HAMMER UNTIL THE TIP OF THE CHISEL IS SHOWING THEN STOP.
Step 4: AND THATS IT YOU HAVE MADE IT.
NOW YOU HAVE A HAND CHISEL THATS KNOWN FROM YEARS AGO.
ITS CALLED-.
THE OLD LADY,S TOOTH.
IF YOU USE A DESCENT CHISEL YOU WILL BE AMAZED AT HOW WELL IT CAN CUT CLEANLY THROUGH WOOD ETC,ETC
THANK YOU FOR TAKING THE TIME TO READ OR DO IT FOR YOURSELF.
BEST WISHES
UTOPIA
