Introduction: DIY HOME AUTOMATION - Replace Traditional Light Switches
Turn on or off LIGHTS using touch sensors
Features:
- Capacitive touch sensors are used to turn on the lights instead of traditional mechanical switches.
- PIR Sensors for automated lights.
Step 1: Materials Needed
1. ESP8266 shield - https://s.click.aliexpress.com/e/_EvKUzHv
2. Arduino UNO - https://s.click.aliexpress.com/e/_EvKUzHv
3. Arduino Mega - https://s.click.aliexpress.com/e/_EvKUzHv
4. Breadboard - https://s.click.aliexpress.com/e/_EvKUzHv
5. Jumper wires - https://s.click.aliexpress.com/e/_EvKUzHv
Step 2: LIGHTS- Selecting the Pins for Touch Sensors and Relays
Here 4 capacitive touch sensors are used. Each one is use to turn on or off the light.
How it works? When the sensor the pressed it activated a relay. The light connected to the relay is then activated. To turn off the light the sensor is pressed again.
______
Pin 22 - Touchsensor1
Pin 23 - Touchsensor2
Pin 24 - Touchsensor3
Pin 25 - Touchsensor4
______
Pin 26 - Input 1 of relay (Relay1)
Pin 27 - Input 2 of relay (Relay2)
Pin 28 - Input 3 of relay (Relay3)
Pin 29 - Input 4 of relay (Relay4)
______
Touchsensor1 activates Relay1 and so on...
Step 3: LIGHTS - Selecting Pins for PIR Sensors and Relay
There are two lights that are activated by the PIR sensors.
______
Pin 30 - PIR1
Pin 31 - PIR2
_______
Pin 32 - Input 5 of relay (Relay5)
Pin 33 - Input 6 of relay (Relay6)
_______
PIR1 activates Relay5
PIR2 activates Relay6
Step 4: Programming the Arduino
// Pins for capactitive touch sensor
#define TouchSensor1 22
#define TouchSensor2 23
#define TouchSensor3 24
#define TouchSensor4 25
// Pins for PIR sensors
int PIR1 = 30; //
int PIR2 = 31; //
int val1 = 0;
int val2 = 1;
boolean currentState1 = LOW;
boolean lastState1 = LOW;
boolean RelayState1 = LOW;
boolean currentState2 = LOW;
boolean lastState2 = LOW;
boolean RelayState2 = LOW;
boolean currentState3 = LOW;
boolean lastState3 = LOW;
boolean RelayState3 = LOW;
boolean currentState4 = LOW;
boolean lastState4 = LOW;
boolean RelayState4 = LOW;
// Pins for relay
int Relay1 = 26;
int Relay2 = 27;
int Relay3 = 28;
int Relay4 = 29;
int Relay5 = 32;
int Relay6 = 33;
void setup() {
//define relays as output
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
//define touch sensors as input
pinMode(TouchSensor1, INPUT);
pinMode(TouchSensor2, INPUT);
pinMode(TouchSensor3, INPUT);
pinMode(TouchSensor4, INPUT);
THE FULL CODE IS AVAILABLE TO DOWNLOAD BELOW
CLICK ON THE FILE X.ino to download.
Step 5: CIrcuit Diagram - Wiring Light to Relay
This picture is self- explanatory.
Beware risk of electric shock
