Introduction: DIY Hamster Cage
This is my do it yourself hamster cage for Dustin, a djungarian dwarf hamster. I used 4 precut panels which I screwed together. For the large window I used acrylic glass which I cut in size. It's a pretty easy build, which only requires basic tools and skills.
- 2x 80x40cm for the back and bottom auf the cage
- 2x 80x30cm for the side/feets
- 1x acrylic glass sheet for the front window
- Wood screws and screwdriver
- Box cutter
- Acrylic glass glue, I ve used B7000
Step 1: Cage
For the cage you only need 4 panels. Use coated wood panels, as the hamster's body liquids may damage normal wood.
- Lay the panels on the floor. The 80x40 panels are in the middle, the smaller 80x30 panels on the side
- Screw the 80x30 panels to the larger panel as shown in the pictures. Use at least 2 screws on each side.
- Now screw the 80x40 bottom panel to all three panels. Again, use at least 2 screws on each side
- Fill the gaps with hot glue. Add the hot glue from the back so the hamster can't nibble on it.
Step 2: Acrylic Glass Window
You want to watch the hamster. So you need to make a see through window. The most affordable way is to use acrylic glass and cut it in size. You need 1x 80x40 and 2x 10+x40 panels. 2mm thickness is enough.
- Cut the acrylic glass sheet in size. Use a box cutter and a steel liner. Be careful!
- Glue the side panels first to the cage. Use glue on the inside and outside.
- Insert the main panel in the front. Again, use glue in the inside and outside.
- Let the glue dry.
Step 3: Interior
For the interior, you are free to decide how to decorate the cage. But your hamster needs at least caves to hide, a wheel to run, a drinking bottle and a food tray. Here are some tips:
- I ve installed the water bottle on the acrylic glass. I used a solder iron to make a hole for the installation.
- I used quite a lot of bedding as hamsters like to dig.
- I also installed a sand bath (Ikea FÖRVAR)
- I installed a second floor to give the hamster more space to run and hide.
Step 4: Finished!
Dustin, my Djungarian hamster loves his cage. I hope you liked my project too. Enjoy!
