Introduction: DIY Hand Ground Tamper
I needed a hand ground tamper for a backyard project (ground prep for an above ground swimming pool) but didn't want to spend $40 or more. Instead, I created a DIY hand tamper using common materials found in the garage. It took me less than 15 minutes to make it.
Hardware
- 1/4" bolts x2
- 1/4" nuts x2
- 1/4" washers x4
- Note: other size bolts may work as well. I already had 1/4" bolts on hand.
- 2" (or longer) wood screws x2
- Zip ties x4
Lumber
- 2 x 2 x 60" dimensional lumber
- 2 x 4 x 5" dimensional lumber
- 3/4 x 8 x 8" plywood
Other
- 5 lb weight x2
- Plastic bag x2
Tools
- Wood saw
- Drill
- 1/4" drill bit for drilling bolt and zip tie holes
- Screw bit for driving screws
Step 1: Make the Plywood Base
- Cut a piece of 3/4" plywood to 8" x 8".
- Drill 8 holes through the plywood base, as shown in the picture, for the zip ties to pass through.
- With wood screws, screw the piece of 2 x 4 x 5" wood into the plywood base slightly off-center, as shown in the picture. Make sure it is positioned slightly off center so that when the handle is attached to it in a later step, the handle is in the center.
Step 2: Attach the Handle and Weights to the Plywood Base
- Drill two holes through the 2 x 2 x 60" handle and 2 x 4 x 5" wood so that the 1/4" bolts can pass through them.
- Connect the 2 x 2 x 60" handle and 2 x 4 x 5" wood with 1/4" bolts, washers, and nuts.
- Place each 5 lb weight inside a plastic bag to keep them clean.
- Place a 5 lb weight on the base and secure it with 2 zip ties.
- Repeat step 4 for the other 5 lb weight.
Step 3: Conclusion
This is what the finished product looks like in my case. Yours might be different depending on whether different materials, dimensions or weights are used.
Here is a link to a short video of this ground tamper in action (please watch until end of video). https://youtu.be/MFXfX4eNFUQ
