Introduction: DIY Hanging Home Sign Decoration
Happy April! I hope that you are all doing well. Today we're creating a hanging home sign decoration. We are using just a few materials to create this home sign decoration. As always, I will provide you with a material list and step-by-step instructions.
One wooden sign or wood plaque
Wooden letters
Ribbon
Wooden beads-optional
Twine
Scissors
Paintbrush
Hot glue or any adhesive of your choice
Faux floral
One wooden crate
Acrylic paint
Step 1: Applying Paint to Your Wooden Board
Before applying my paint, I decided to use my scissors and remove the beads from my sign. I reuse them later in my design. After removing my beads, I applied brown acrylic paint to my wooden sign. I used a little water to thin out my paint when applying it to my wooden board.
Step 2: Applying Paint to Wooden Crate and Wooden Letters
Next, I took my wooden crate and applied paint to the front, top, and sides of my box. Next, I applied paint to my wooden letters.
Step 3: Applying Paint to Beads and Adding Them to the Twine
I decided to add my brown paint to the beads I removed earlier. I am using eight beads in my design. I used a paper towel when applying my paint to the beads. After, take the beads and begin to string them onto your twine. Next, flip your board, and use hot glue to attach your twine and beads to your sign. I decided I wanted my board to be vertical instead of horizontal. That was why I removed the beads from my sign in the very beginning.
Step 4: Adding Crate and Letters to Wooden Sign
Next, take the wooden crate and attach it to the bottom of your sign. You can use wood glue. I used hot glue. Add your letters to your sign.
Step 5: Adding Ribbon and Foam Block
Take your scissors and cut some ribbon. This is optional, but I decided to add my ribbon across my wooden crate. After, take your foam block and add it inside your wooden crate.
Step 6: Adding Floral
All that is left is to add your floral to the foam block. Cut your floral to size and begin to insert them into the foam block. If you have any ribbon left over, you can create a bow to add to your decoration.
Step 7:
Thank you so much for stopping by and creating this craft with me. While you're here, be sure to check out more DIY crafts and home projects.-https://stephcreatesthingsdiyhomeandcrafts.blogspot.com/ For more video tutorials click the link- Steph Creates-DIY Home & Crafts
