Introduction: DIY HiFi 200 Watt Audio Amplifier
Hey! everyone My name is Steve.
Today I’m Gonna show how I Build this Class D Audio Amplifier Using TDA3116D2 Board it Can deliver up to 100 watts each channel This amplifier uses 2 TDA3116D2 Chip each can do 100 watts @2 Ohms
Amplifier Type is Class D
Sound Quality is really impressive
For Test, I’m gonna use only 3” 30-watt speakers
You can easily drive 6”-8” inch drivers
Let's Start
Step 1: Features
Input Power
- 100-240V AC
Output Power
- 100 Watt x 2 @ 2Ohms
Built-in Protection
- Over Load Protection
- Short Circuit Protection
- Over Heat Protection
Step 2: Thing I've Used
LCSC
- 10K Potentiometer - http://bit.ly/346Secx
- Stand-Off - http://bit.ly/2PpsxyI
LCSC 8$ OFF on your first order - https://lcsc.com/?href=STEVE&source=referral
Banggood
- TDA3116D2 Amplifier - https://bit.ly/2PTgM6F
- 24v SMPS - https://bit.ly/2PTgM6F
- Aluminium Encloser - https://bit.ly/2PTgM6F
- AC Socket with Switch - https://bit.ly/2PTgM6F
- Speakon Connector Female - https://bit.ly/2PTgM6F
- Speakon Connector Male - https://bit.ly/2PTgM6F
- 3.5 mm Female Socket
- 10K Potentiometer
- LED with led socket
- Rubber Feet - https://bit.ly/2PTgM6F
- Soldering Iron - https://bit.ly/2PTgM6F
- Drill Bit - https://bit.ly/2PTgM6F
- Heat Shrink Tube - https://bit.ly/2PTgM6F
- PCB Stand-Off - https://bit.ly/2PTgM6F
- Hole Punch Center - https://bit.ly/2PTgM6F
13% Off for Electronics Category coupon code: BGE13
Amazon
- TDA3116D2 Amplifier - https://amzn.to/2S9D94w
- 24v SMPS - https://amzn.to/2S9D94w
- Aluminium Encloser - https://amzn.to/2S9D94w
- AC Socket with Switch - https://amzn.to/2S9D94w
- Speakon Connector Female - https://amzn.to/2S9D94w
- Speakon Connector Male - https://amzn.to/2S9D94w
- 3.5 mm Female Socket - https://amzn.to/2S9D94w
- 10K Potentiometer - https://amzn.to/2S9D94w
- LED with led socket - https://amzn.to/2S9D94w
- Rubber Feet - https://amzn.to/2S9D94w
- Soldering Iron - https://amzn.to/2S9D94w
- Drill Bit - https://amzn.to/2S9D94w
- Heat Shrink Tube - https://amzn.to/2S9D94w
- PCB Stand-Off - https://amzn.to/2S9D94w
Aliexpress
- TDA3116D2 Amplifier - http://bit.ly/2zq2y33
- 24v SMPS - http://bit.ly/2zq2y33
- Aluminium Encloser - http://bit.ly/2zq2y33
- AC Socket with Switch - http://bit.ly/2zq2y33
- Speakon Connector Female - http://bit.ly/2zq2y33
- Speakon Connector Male - http://bit.ly/2zq2y33
- 3.5 mm Female Socket - http://bit.ly/2zq2y33
- 10K Potentiometer - http://bit.ly/2zq2y33
- LED with led socket - http://bit.ly/2zq2y33
- Rubber Feet - http://bit.ly/2zq2y33
- Soldering Iron - http://bit.ly/2zq2y33
- Drill Bit - http://bit.ly/2zq2y33
- Heat Shrink Tube - http://bit.ly/2zq2y33
- PCB Stand-Off - http://bit.ly/2zq2y33
Step 3: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 4: Wiring Diagram
Note - Please see the images for better understanding
Step 5: Marking & Drilling
- I Used a Philips Head Screw Driver to Open the Encloser
And Then I placed the SMPS and Amplifier one by one on top of the bottom part of the Encloser and used a Center Punch to Punch 4 Holes for SMPS and 2 holes for Amplifier
And then I used a 3mm Drill Bit to Drill the Punches
Step 6: Drilling Back Panel
- For AC Input Socket I've traced the square on the back panel
- And then used 4mm drill it to cover all the traces "See the Image"
- And then used a Dremel tool to trim
- And then used a bigger file to trim more
- and then used a small file for finishing
- For Audio Output I used a Female Speakon Socket So, I used a 3mm Drill Bit to drill the corresponding holes and then I used a Step Drill bit to enlarge the holes
Step 7: Drilling Front Panel
- For Volume Controle I used a 10K Dual Gang Potentiometer So, I used a 3mm Drill Bit to drill the corresponding holes and then I used a Step Drill bit to enlarge the holes
- For led and 3.5mm audio input socket I've used 4mm drill bit
Step 8: Assembling of Back Panel
- First, I pressed the AC socket and it automatically locked in the place
- And then I Installed Female Speakon Connector using 2 Screws
- And then soldered wire according to the Wiring Diagram
- And then used some heat shrink
Step 9: Assembling of Front Panel
- First, I Installed the Potentiometer
- And then installed the 3.5mm Audio input Socket " See the Image "
- And then installed the Led Socket
Step 10: Mounting for Amplifier
For mounting the amplifier I've made an L Bracket using aluminium and drilled 2 3mm hole
Step 11: Assembly
- First, I Inserted the SMPS and then I've used 4 M3 Screws to tighten it up
- And then I closed the Back panel and used 2 M3 Screws to tighten it up
- And then I've screwed 2 wire along with 2 led wires
- And then I closed the Front panel and used 2 M3 Screws to tighten it up
- And Connected all the wire according to the wiring diagram
- And then I've inserted the amplifier and then used 2 M3 Screws to tighten it up
- and did the rest wiring
Step 12: Fuse
- This AC socket comes with the Fuse box So, I've put a 2Amp fuse in it
- Make sure to put the fuse otherwise, it will not work
Step 13: Final Assembly
- I closed the Upper panel and used 4 M3 Screws to tighten it up
- And then I've put the volume control knob
- Lastly, I used 4 rubber pad
Step 14: Setup and Enjoy
- Plugged the Power Cable
- Plugged the Speakon Connector
- Plugged the 3.5mm Audio Jack
- Turned the Switch On
- The Amplifier is Finished
- Now Just play and Enjoy
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
