DIY Gandalf's Pipe.
Intro: DIY Gandalf's Pipe.
Try the Gandalf Style !!
As you all know the Pipeweed its so rare, so In order to enjoy the good taste of Tobacco I made an enjoyable article that helps to relax in the long journeys by the Forest.
Its gifts time and I was wondering how to surpriseĀ a friend of mine that loves the Lord of the Rings Saga and of course the new movie The Hobbits and why not make another one for me.
STEP 1: Stuff.
Stuff:
Walnut Seed.
Drill.
Big drill bit.
Dremel.
Sand Paper.
Thin Holed Branches.
Varnish.
Walnut Seed.
Drill.
Big drill bit.
Dremel.
Sand Paper.
Varnish.
STEP 2: Tobacco Chamber.
For the Tobacco chamber I used a Black Walnut Seed from my granpa's backyard.I used a big drill Bit to make a hole carefully that doesn't break the seed.Then put the seed in the Drill and start to sand with rough sand paper then with thin Sand paper, until, the surface take a smooth looking.Finnally I open on the side of the seed a hole where the stem is glued with Wood Glue.When the stem is sticked and after a couple of hours when the glue has dryed I applied Clear Varnish.
STEP 3: Stem.
This is on the tricki side because I just dont know what kind of branch I find in the forest that was with a hole in all the branches.I just remove the interior with a wire and remove the inside parts of the branches.Apply Varnish once the Chamber and stem are glued together.
50 Comments
99connor 10 years ago
star-lord6 3 years ago
balderd 7 years ago
Try tagua nut (aka vegetable ivory) for the bowl.
Mr.Sanchez 7 years ago
balderd 7 years ago
JayC113 7 years ago
Try using hardwood for the stem. Drill the center and place an opened wire coat hanger in the drilled hole. Wrap a length of twine length wise from hole to hole. twist a long bolt in one side of the twine. Soak the stem in water for a few days. After soaking take the stem out twist the bolt a few more times, and place back in the water. Repeat this until you have the desired curve, then place in a dehydrator on low until moisture is gone. Remove twine and wire from stem, then carve to desired shape.
Jake_Makes 9 years ago
Try bamboo with a heat gun to curve the stem.
wrongperson 8 years ago
bcavaciuti 10 years ago
oud25 11 years ago
is elderberry strong enough to use?
Mr.Sanchez 11 years ago
skenney2 11 years ago
tigr87 11 years ago
Could I use a avocado seed?
Could you carve it?
I also heard they have trace amounts of arsenic in them, so would that be a problem?
tigr87 11 years ago
Toxic plants (including parsley)
Metal polish
Avocado
Chocolate
Moldy grains/seeds
assassinsarmy 10 years ago
tigr87 11 years ago
