DIY Homemade Vacuum Cleaner Using Computer Cooling Fan
Intro: DIY Homemade Vacuum Cleaner Using Computer Cooling Fan
In this video i will show you how to build your own DIY vacuum cleaner
STEP 1: Making Video
STEP 2: Things Required
1. Plastic Bottle
2. Bottle Cap
3. Another Cap with length 3 to 5 Cm
4. Cloth with Filter
5. 12 Volt Computer Cooling Fan
6. Scale, Sketch Pen & Knife
7. Insulation Tape
8. Scissor
9. Soldering Rod, Soldering Wire & Soldering Paste
10. Wire Stripper
11. Glue
12. Packing Tape
13. Few Pieces of Cardboard Sheets
14. Plastic Container with Lid
STEP 3: Wiring
STEP 4: Construction
1st Image - Cut the bottle at the top
2nd Image - Now place the cut piece at an angle and mark it with a sketch pen / marker as shown in 3rd Image
4th Image - Now cut & remove the marked part
5th Image - Now remove the bottom section leaving about 6 to 8 Cm
STEP 5: Construction
1st Image - Shows how the nozzle will be placed
2nd Image - Now cut the cap an angle
3rd Image - Make a hole in the bottle cap
4th Image - Make a hole in the plastic container
STEP 6: Construction - Joining
1st Image - Now Glue the bottle cap & the white cap
2nd Image - Now glue the container to the plastic bottle (Note : in this image you can see there is a filter which is not required hence it was not shown here but it shown in the making video
3rd Image - Join the Nozzle part to the plastic bottle
STEP 7: Construction - Filter & Fan
Now to create filter
1st Image - Mark the size of the fan and
2nd Image - Now remove the center part so that air can flow (You need 2)
3rd Image - Now glue the filter to one of the cardboard sheet
4th Image - Now place the another card board sheet over it & glue it
(Placement = Cardboard sheet - Cloth - Cardboard Sheet)
5th Image - Now place the container lid and mark the center part which has to be removed
6th Image - Once the center part is removed glue it to the one side of the filter
7th Image - Now glue the computer cooling fan to the other side
8th Image - Now cover all the sides of the fan and add a switch(optional)
STEP 8: Finished Images
To watch the testing of the vacuum cleaner please CLICK HERE or go to the step 1 (Making Video)
Testing begins @ 10:40
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US :
Computer Cooling Fan : http://amzn.to/2a7X3u2
Switch : http://amzn.to/29YN5L4
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Insulation Tape - http://amzn.to/29YNZax
Scissor - http://amzn.to/29Y1K65
Hot Glue Gun - http://amzn.to/29Y2BU8
Wire Stripper & Cutter - http://amzn.to/29RBsm8
Amazon India :
Computer Cooling Fan - http://amzn.to/2a0r3sq
Switch : http://amzn.to/29SqL6Z
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Insulation Tape - http://amzn.to/29HGzpJ
Scissor - http://amzn.to/29P2ECE
Hot Glue Gun - http://amzn.to/29HEslT
Wire Stripper & Cutter - http://amzn.to/2a0wBD8
Please Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
Instagram : https://www.instagram.com/makestuff_ms/
Google Plus : https://goo.gl/RpTnwf
Facebook : https://www.facebook.com/makestuffMS
THANK YOU FOR READING !!!
