Introduction: DIY Honeycomb Pin Board
Those in need of a crafty project to tackle this weekend that will also help them be a little more stylishly organized might enjoy this easy-to-do reader-submitted honeycomb pin board project, which features a simple shape repeated in cute colors that you can hang on your wall and add a little pattern, too.
Project cost: About $20 Total time: 3 hours
Step 1: Materials
What you need
Materials
White foam board (3 mm and 5 mm thick)
Compass
Double sided adhesive tape
Ruler, pencil, scalpel or cutter
Colored self adhesive foil or contact paper
Materials
Compass
Step 2:
Draft a hexagon with the compass on the 3 mm thick foam board then cut.
then use it as a stencil to make 24 more pieces.
Step 3:
Cover them one by one with the colored foils.
Step 4:
Stick double sided adhesive tape to the 5 mm thick foam piece and attach the hexagons as you like (you can even have gaps in the middle).
Step 5:
Finally, cut around the board to create a composition of hexagons that are actually one whole (easier to hang) piece.
Step 6:
To avoid holes in the pin board, place pins in the corners or between the edges of the hexagons. Individual hexagons can be used as glass or mouse mats.
Step 7: You're Done.
Now you've got your own pin board made by you. Give yourself a pat on the back.
~bearbear
~bearbear
