Introduction: DIY Hovercraft Toy (using a CD)
Build your own toy hovercraft using a compact disc and a balloon. Pretty simple !
Video Tutorial on Youtube
WATCH HERE : DIY Hovercraft Toy (using a CD)
Hovercraft use blowers to produce a large volume of air below the hull that is slightly above atmospheric pressure. The pressure difference between the higher pressure air below the hull and lower pressure ambient air above it produces lift, which causes the hull to float above the running surface.
For stability reasons, the air is typically blown through slots or holes around the outside of a disk or oval shaped platform, giving most hovercraft a characteristic rounded-rectangle shape.
My Facebook-Fanpage !
https://www.facebook.com/ehlerstv
Follow me on Twitter:
https://twitter.com/Ehlers_TV
Step 1: You Need:
- a CD (Compact Disc)
- a pin
- a plastic bottle cap
- a balloon
and HOT GLUE
Step 2: The Pin
Make some "air-holes" into the bottle cap....
Step 3: The Bottle Cap
Take the bottle cap and put it in the middle of the CD ( over the hole)...
...stick firmly around the cap using hot glue....
Step 4: Balloon
Take a balloon, blow it up..twist the end (airtight) and put it over the bottle cap.....
