Introduction: DIY--How to Install TV Digital LED Strip
DIY LED Strip Magic to Illuminate Your TV: 11 Easy Steps to Transform Your Viewing Experience!
Addressable LED Strip Link
Mini LED Controller Link
LED Cable Link
Scissors
Step 1:
Clean the back of the TV with a dry towel.
Step 2:
Unroll the LED strip from its packaging.
Step 3:
To avoid splinters on the rest of the glue, expose a small amount of adhesive at a time.
Step 4:
Begin the installation on the left corner of the television, leaving the connecting end dangling over the edge.
Step 5:
Begin by carefully turning on the LED strip. Take your time and go slowly.
Step 6:
Make a 90° loop at each corner before running the LED strip to the next.
Step 7:
Ensure that the LED strip is flat along the whole installation path.
Step 8:
After you've reached the beginning position, cut the extra at the stated cutting mark.
Step 9:
Return to the LED strip and use your fingertips to help the adhesive adhere.
Step 10:
Connect the power supply to the IR receiver (the white box receiver). Connect the IR receiver to the LED strip. Check that the arrows on both connections are parallel.
Congratulations, you have completed your task. Just plug it in and enjoy the TV light show.
