Introduction: DIY How to Make Wall Hanging Lamp From PVC || Super Easy DIY Wall Sconces!
Hello!
Today, I will show you How To Make Wall Hanging Lamp from PVC pipe! Its Super Easy DIY Wall Sconces and everyone can make it! I build those lights for my work desk.
Step 1:
For this DIY wall lights you will need just a few things:
- PVC pipes D-50mm
- Ventilation grille D-50mm
- LED lights
- Paint
- Hot glue
My tools:
- Saw
Step 2:
I decided to make a Wall Spot Lights for my desk. I used PVC pipes and led lights. To attached lamp to the pipe, i have to cut those "ears". The size of lamps is a little bit smaller than the size of the pipe. That's why i made this PVC ring.
Step 3:
I made such constructions from wood pieces, so i can cut pipe straight. Legs for my spots i made from wood. I attached it to the PVC pipe with hot glue. When the glue cool down i cut off melted glue. And drilled holes for electric wire.
Step 4:
For decoration, I used such a ventilation grille. In addition, this will allow hot air to escape from the lamp. I cut off the edges with a pair of metal scissors. Now the grille is installed perfectly. It remains to paint the lamps and wait for the paint to dry.
Step 5:
I connected the wires to the light bulb with quick connectors. Inserted bulb to the PVC pipe and the lamp is ready! When i build a Wood Slat Wall, i used the same piece of wood as i used for the base of my lamp. Thats why it fits perfectly to my slat wall. If you are interested How I Build a Wood Slat Wall With Floating PC Desk you can watch my video. I think i will post Instructable a little bit later.
Step 6:
I used 3 watt light bulbs. They do not heat up the plastic pipe.
Step 7:
Hope you like it! See you later!
