Introduction: DIY How to Make a Beaded Chain Bracelet
This bracelet is made up of loops of wire, threaded with beads. It can be fairly time consuming to make (though no more so than if you were making a normal handmade chain). However, the effort is worth it, as you'll produce a unique, eye-catching bracelet.
Step 1: Select the Jump Rings
You can either make these yourself or buy them. Make sure that they are big enough to thread the beads on to and that you have enough of them.
Step 2: Open the Jump Ring by Twisting the Two Sides Away From Each Other With Pliers
Do not pull the ends jump ring apart outwards, as this will change the shape of the ring.
Step 3: Thread the Beads Onto the Jump Ring
Use odd numbers of beads in coordinating colours for the most aesthetically pleasing design.
Step 4: Close the Jump Ring
Ensure that the ends are pressed tightly together to prevent the chain from falling apart.
Step 5: Make a Chain
Create as many of these as you need to make your bracelet, linking them together to make a chain.
Step 6: Attach a Clasp to Your Bracelet
There are many clasps available, so choose whichever you prefer.
Step 7: Finished
All work is finish and now you've good beaded chain Bracelet.
Thanks For visit, share, comment, add to favorite and if contest is going on so please vote me by clicking vote button on this page of upper right side.
Again Thank you...
I've made this instructable for just sharing purpose and data is taken from wikihow.
