Introduction: DIY INDUSTRIAL PIPE SHELF
Today I wanted to show you how you can build a quick and inexpensive industrial pipe shelf for your room that gives it instant character and industrial feel. Enjoy!
Step 1: MATERIALS
To get started on this build you need black pipe and some kind of wood. I prefer to use some kind of reclaimed wood because I think the more beat up the wood looks, the better it stands out against the slick black pipe. Now of course it's up to you what to go with but make sure you have enough length to cover how big the shelves you make are going to be. (In the video above, each shelf is 16.5" long)
The best part of black pipe is it's versatility. You can really make the shelf any design or size that you want. You could add 5 or 6 different shelves at different heights if you wanted to and make it like a whole wall kinda thing. Although if you did that I'd recommend you mount it from the floor to carry the weight. For this shelf, I went with 2 of the same length shelves at different heights. I like to use 3/4" black pipe because it's a little thicker and heavier duty looking. You could use 1/2" pipe if you wanted to and it'd be a little cheaper. The size piping I purchased are as follows.
2 - 12" pieces of black pipe
2 - 6" pieces of black pipe
2 - 4" pieces of black pipe
3 - 3.5" pieces of black pipe
6 - 90 degree elbows
3 - 3/4" floor flanges
1 - 3/4" black tee
All in, the pipe pieces cost me about $50. The wood was free because it was something I had lying around from a previous project.
Step 2: LAYING OUT THE PIPE
Next I recommend laying out the pipe pieces the way the shelf is going to be constructed. You can adjust which pieces you use for what, and which shelf you'd like higher than the other. Again, just a matter of preference.
With the piping laid out I recommend measuring between the pipes where the shelf is going to go. Measure center to center on each end. Once you have that measurement, add a bit on each end so you get around a half inch overhang on the shelves. That will be the length you cut the wood.
Step 3: CUTTING THE WOOD
Cut the wood to the length of the shelves you're making. In the video above each shelf is the same size so I cut each piece at 16.5" long. You can use a chop saw or circular saw for this. Or whatever saw you can get your hands on really.
I've got this old piece of reclaimed walnut which has the old mill lines in it which gives it some great character!
Step 4: LAYING OUT AND DRILLING HOLES
This can get slightly tricky if you use reclaimed live-edge wood because it's tough to make things square. That's okay! You don't need things to be truly square, you just need to make sure that you have enough clearance from the back of your wood so that it doesn't hit the wall and your shelf not able to be hung. In my case, the floor flange and the 3.5" spacer pipe came out to be about 4 5/8" from the back wall so when I laid out my holes, I placed them roughly 4 1/4" from the back edge of the wood so I had plenty of clearance.
Then I traced around the piping and marked the center point of those circles. Using a 7/8" forstner bit (1/8" wider than my pipe diameter), I drilled out the holes on each shelf.
Step 5: FINISHING AND ASSEMBLY
To finish my shelf, I chose to just lightly sand the wood starting with 120 sandpaper and going to 220 grit. I didn't want to lose the old sawmill marks on the shelf so I didn't overly sand it. Then I sealed the shelf with 4 coats of Minwax Satin Finish Spray Polyurethane.
Step 6: FINISHED PRODUCT!
I hope you enjoyed this project and it has inspired you to tackle something similar! For more information on the project, make sure you check out the video and be sure to like, comment and subscribe!
Good luck and get building!
21 Comments
5 years ago
Hi Aaron! I going to make the same shelf to the garage.
Tell me pls - what is the weight of the shelf and what kind of paint you used? What about primer?
Reply 5 years ago
Sorry for the delay. I suggest hitting me up on instagram in the future as I check my messages more frequently there. I did not use paint on this project. Just spray polyurethane to seal the pipes from rust. For the weight, this shelf weighs about 20 lbs.
7 years ago
Absolutely beautiful :)
Reply 7 years ago
Thanks very much!
7 years ago
These metal pipes always have a nice rustic look. I super like them! It is shame that they do not sell them here in my country.
Reply 7 years ago
Ive been toying with the idea of using PVC and mimicking the look. That would help considerably with saving money. It's just a simple act of spray painting it black then pewter color.
Reply 7 years ago
Did you try pvc already? Did it work?
Reply 7 years ago
I wouldn't trust PVC to carry much weight.
Reply 7 years ago
You'll be suprised!
7 years ago
Hey, nice job. I'm trying to do something like that here in Brazil, but people say its not possible to make threads in a black pipe. They can only do that on a galvanized tube, but if i use it, it will become way more expensive. Is there any manual tool to make threads on a black pipe?
7 years ago
awesome..
7 years ago
awesome..
7 years ago
THIS IS VERY COOL!!..
7 years ago
I think your project is brillant. I look forward to making one for my daughter and family members. Thank you for such a fantastic idea.
7 years ago
I love this look! Nice work!
Reply 7 years ago
Thanks!
7 years ago
Hi! I love this idea! Just wondering do the shleves move at all? Going by the photos theres potential for them to rock on the pipe?
Reply 7 years ago
There is minimal movement with the shelves because the hole is just about the same size as the pipe. You could really wedge the pipes in there and eliminate the movement.
7 years ago
Superb !! great job
7 years ago
Nice! Is that a metal pipe or PVC? Just wonding... :)
