Introduction: DIY IPad / Tablet Hologram
Create a stunning visual experience using simple items, your tablet and just a couple of minutes of time!
- iPad or Tablet
- Plexiglass or any transparent foil from old packaging
- Scissors and transparent duct tape
Step 1: Create Paper Template
Create a paper template trapeze with the measures shown in the image.
In case it's hard to read:
Long upper end: 18 cm / 7 inch
Short lower end: 9 cm / 1.2 inch
Height: 10.5 cm / 4.1 inch
Step 2: Cut Plexiglas / Transparent Foil Into Small Pieces
This way you can handle them better.
Note: We made the mistake and bought plexiglas with 2 mm that was rolled up. It's way better to get non-rolled up plexiglas that is flat when you buy it. If you need to flatten it, you can use a hairdryer to apply some heat to it. This we you can get it flat.
Step 3: Tape Template Onto Foil & Cut Out 4 Pieces
Use some transparent duct tape / Tesa to tape the template onto the pieces of plexiglas / foil and cut out pieces of the template. Afterwards, remove the protective foil if there is some.
Step 4: Tape Pieces Together in a Pyramid Shape
Use transparent duct tape / Tesa to tape the pieces together in a pyramid shape as shown in the image
Step 5: Open Pyramid Hologram Videos and Place Pyramid in Middle of Tablet
Grab your Tablet and search for "Pyramid Hologram" on Youtube. Open a video you like, set Youtube to fullscreen and put the pyramid in the middle of the tablet.
Here are some hologram videos we used:
https://youtu.be/Nx0TCwTc2Cg
https://youtu.be/Y60mfBvXCj8
https://youtu.be/asNoWcrfebk
