Introduction: DIY IR Remote Tester Using TSOP1738
Home made remote tester using TSOP1738.
This circuit helps to test the each button of the remote. When you press a button the led in the circuit blinks.
Step 1: Things Required
1. 4.7k Ohm Resistor
2. 10 Ohm Resistor
3. TSOP1738
4. Blue LED
5. PCB Board
6. Wires & Battery
7. Soldering Rod, Soldering Wire & Soldering Paste
8. Hot Glue Gun
9. Remote for Testing
Step 2: Making Video
Watch the making video or continue reading to make you own DIY remote tester
Subscribe To Our YouTube Channel Here : https://goo.gl/ctc8l9
Step 3: Circuit Diagram & Pin Configuration
Step 4: Circuit Construction
1st Image - Mount the TSOP1738 onto the PCB board
2nd Image - Connect the 4.7k ohm resistor to the TSOP1738 pin 2
3rd Image - Now connect the 10 Ohm Resistor to the TSOP1738 pin 3
4th Image - Connect the led to one end of the 10 Ohm resistor
5th image - Connect the positive to end of the 4.7k Ohm resistor
Now ground the Pin 1 of the TSOP1738 & Negative of the LED
Step 5: Finished Images
Enjoy Making !!!
To watch the testing video CLICK HERE
Testing begins @ 3:41
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US:
LED's - http://amzn.to/2a2CTlP
TSOP1738 - http://amzn.to/29WzB0Z
PCB Board - http://amzn.to/2a2Cos5
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
Soldering Kit - http://amzn.to/29RyXjJ
Scissor - http://amzn.to/29Y1K65
Hot Glue Gun - http://amzn.to/29Y2BU8
Amazon India :
LED's - http://amzn.to/29DPA6W
TSOP1738 - http://amzn.to/29Qbnry
PCB Board - http://amzn.to/29Ged2O
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
Soldering Kit - http://amzn.to/29P00wv
Scissor - http://amzn.to/29P2ECE
Hot Glue Gun - http://amzn.to/29HEslT
Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
THANK YOU FOR READING !!!
