Introduction: DIY Ideas With Mosfet - LED Brightness Controller With Push Switch || JLCPCB
In This Project, We’ll Teach You Making A Adjustable
Voltage Regulator Circuit With Push Switch. It Is Also Possible To Make This Circuit Using Potentiometer, But We Follow A Unique Method To Make This Circuit.
Thanks To JLCPCB
$2 For 1-4 Layer PCBs.
Get SMT Coupons: https://jlcpcb.com/RTA
Step 1: Component List
To Make This Amazing Electronics Circuit, We Might Need
Some Electronics Component. Those Component List Have To Been Given Below.
Component List :
1. Mosfet – IRF z44n
2. LDR – Light Dependent Resistor
3. Resistor – 100 KΩ (2 Pieces)
1 MΩ
4. Push Switch – 2 Pieces
5. LED – 12v
6. Film Capacitor – 105j250v
7. Power Source – Dc 12v
8. Heat Sink
Step 2: Mosfet Pinout - IRF Z44n
The Mosfet IRF Z44n Contain 3 Legs. This 3 Legs Have
Different Names. If We Count It’s Leg From Left Side, Then 1st No “Gate”, 2nd No “Drain” & 3rd No “Source”.
Step 3: Circuit Connection - 1
Circuit Connection :
1st Connect 100 KΩ Resistor With “Source” Leg Of Mosfet. Then Connect Push Switch With 100 KΩ Resistor & Connect Other Push Switch With The Empty Terminal Of Push Switch, That Is Connected With 100 KΩ Resistor.
Now We Connect DC-12v LED Light With The Circuit. Connect LED Light Negative Leg With “Drain” Leg Of Mosfet.
Step 4: Circuit Connection - 2
Now We Connect Film Capacitor With The Circuit. Connect This Film Capacitor With “Gate” & “Drain” Leg Of Mosfet.
You Know, We Use 2 Pieces 100 KΩ Resistor. 1 Piece Is Connected With The Circuit. Now We Connect The Rest 1 Piece. We Connect This Due 100 KΩ Resistor With The Empty Leg Of Push Switch And “Drain” Leg Of Mosfet.
Now We Connect The 1 MΩ Resistor With The Circuit. Connect This 1 MΩ Resistor With The Joint Place Of 2 Push Switch And The “Gate” Leg Of Mosfet.
Step 5: Last Step
It Is The Time To Use The LED Brightness Controller
Circuit. When You Push 1no Switch, Then The Led Light Will Glow Up & When You Push 2no Switch, Then The LED Light Will Glow Down.
Connect The Mosfet With The Heat Sink & Enjoy The Circuit.
