Introduction: DIY Interactive Robot Using REKA:BIT With Micro:bit
Let's build an interactive robot! 🤖
Not the kind that talks to you per se, but the kind that goes all happy when you start to tickle it! In short, a humanoid Tamagotchi!. 🦾
Curious but can't imagine it? Then come join me and learn how to build it using a REKA:BIT! ✨
Step 1: Components and Tools
Electrical Components Required:
- 1x REKA:BIT board with MicroBit v2 (Notice we're using MicroBit v2 in order to work with its sound & touch sensors)
- 2x Servo motors attached to ice cream sticks
- 2x TT Motor + Wheel Kit
- 1x Potential Meter 10K
- 4x LED
- 4x Resistors (the resistance value can be ranged from 100Ω to 2kΩ)
- 3x Grove to female cable
- 6x Male to male wires
- Battery holder
Tools Required:
- Breadboard
- Cardboard
- Hot Glue Gun
- Scissor
- Cable ties
All listed components can be found on Cytron Technologies' website!
Step 2: Use Cardboard to Make the Robot Body
- Cut cardboard to the dimensions shown in figure 1, (Note: you can print the robot template by clicking here!)
- Use the glue gun to attach the side parts as shown in figures 2, 3.
- Attach the breadboard holder as shown in figure 4. and make sure to leave a little space for the ease of wire connection as shown in figure 5.
Step 3: Connection
- The first grove port of REKA:BIT will be connected to the potentiometer, as shown in figure 1
VCC => 3v3 pin
GND => GND pin
OUTPUT => Pin 1 (P1) - Connect LEDs to the breadboard, as shown in figure 2
where:
The long leg (Anode) should be connected to the output pin.
The short leg (Cathode) should be connected to a resistor, and the resistor will be connected to the ground pin.
After that, connect the female wires that coming from the grove port to the male wires on the breadboard. - Connect both servo motors to the servo ports number 1 and 2
- Connect the DC motors to their terminals
In the end, your connection should be similar to figure 3
Step 4: Attach Components to Cardboard
- Insert the potentiometer in the middle
- Place the breadboard over the cardboard piece
- Attach servo motors
- Place DC motors on the bottom sides
- Attach REKA:BIT and fix it using cable ties
- Insert the caster wheel into a piece of cardboard and place it at the bottom
- Place the battery holder over the cardboard piece
- Make the circuit connection as shown in the previous step
- Attach the ice cream sticks to servo motors
- Close the top side with a cardboard piece
Step 5: Code
Now, connect the MicroBit to your device and open MakeCode editor to start programming.
- Add REKA:BIT extension and follow the code block in the picture above
- After completing the code block, download it and compile it over REKA:BIT
You can also view and edit the code by clicking here!
Step 6: Well Done!
Awesome! the interactive robot is ready to go.
Turn on REKA:BIT and enjoy having fun with it.
Don't forget to show your cool robot to your friends!
Have a good day, Maker :)
