Introduction: DIY Interior Design Beds and Bedside Table
In my flat I used to have a bed made of recycled wooden pallets, but after few years it became completely uncomfortable and I had the feeling it could crack in any time.
So I start thinking about an alternatives to the wooden pallets, despite they are easy to find, practical to use and basically for free.
Step 1: Why PlayWood?
Talking to a friend, he suggested me to use two different qualities of wooden boards mainly for two reasons:
the structure would have been more solid and robusttwo wooden shades are more pleasant to see than the cheapest pallets wood I could find in a landfill. I heard my friend and decided to realize my brand new bad using fir layers panels and OSB with white bilaminate edged; I bought them in a common DIY store, where I also asked about their thickness: Each boards is between 16 and 19 mm thick (¾” and ⅞”), thus I already decided to assemble my project through PlayWood angle connectors. (Of course you may use metal angle connectors, as well.) I rather use them because they are made of top-quality recycled plastic materials and they are sustainable for the environment, extremely practical and simple to use.
Step 2: What Do I Need?
For the realization of this design I used:
- 8 Connectors 90°
- 8 Connectors 105°
- 8 Fir Layers Boards 40 x 30 cm - 15,75” x 11,81”
- 1 OSB + White Bilaminated Edged Board 200 x 100 cm - 78,74” x 39,37”
- 1 OSB + White Bilaminated Edged Board 100 x 30 cm - 39,37” x 11,81”
Step 3: How Do I Build It?
The assembly wasn’t really hard to do: quite the opposite!
Firstly I joint two small boards through two angle connector 105°; I did the same action with other two small boards and connected these structures with other two PlayWood angles 105° and a long fir layers board. Doing so, I realized the basement of my bed.
After that I began creating my bedside table: The simplest thing ever! 4 small OSB boards joint through 4 angle connectors.
Eventually, I put the largest OSB board on the top of the previously obtained basement and in very few steps I decorated my bedroom in a cheap and fast way!
Step 4: What Are You Waiting For?
That’s the beauty of DIY projects: I feel completely fulfilled and happy with the result and, more importantly, each piece I used can be recycled and assembled in many different ways, thanks to the versatile assembly system.
