Introduction: DIY Japanese Aluminum Foil Ball
Today, I try out the popular trend that's been spreading across the internet. I use a aluminum foil and hammer them down to create this dense aluminum ball. I polished these Japanese foil balls using sandpaper until it becomes a solid metal polished ball, then I polish it using metal polishing liquid. So here's what I did!
Step 1: Tools Needed
To make the Japanese Aluminum Foil Ball you will need:
1- Aluminum Foil
2- Hammer
3- Sanding Paper
4- Metal Polishing liquid and Sponge
Step 2: Hammering
Start making a ball from the Aluminum foil, once it become rounded start hammering it by the hammer to make it a sold ball.
this task takes time and you should be careful in order to keep the ball rounded.
Step 3: Sanding and Polishing
After it become perfectly rounded and all the Aluminum came together, start sanding it with the sanding paper, the finer sanding paper the better. once it is very smooth and shining. Polish it with the metal polishing liquid and sponge to make it reflective like a mirror.
Warning : this task is the most time consuming and tiring. if you have a polishing machine USE IT!
Step 4: Final Output
After doing all the steps above the final product will look something like that or even better.
Show me your results in the comments guys!
Thank You!
