Introduction: DIY Kulturbeutel
In this instructable I'm going to show you a quick DIY sewing idea, what you can make using your odds and ends of fabric. There a planty of possibilites how to use your fabric remnant but in this instructable we are going to make a simple yet beautiful "Kulturbeutel". You hardly need any fabric for this bag. Whether for small bits and cosmetics or as a pacifier bag, it's definitely something to look forward to.
It's time to get this thing done. I wish you a happy and fun time!
  1. Any fabric remnant will do but I used a 42x32 cm long, 400g/m2 heavy remnant out of 100% Polyester. It's up to your conditions and taste.
  2. A (colour-coordinated) thread and needle or a sewing machine if available
  3. A 42 cm metal zipper (color should be convenient to the textile)
  4. A sissor
  5. A ruler
Step 1: Sewing The
Position your fabric facing up on your work surface. Position your zipper so that it is face up with the zipper pull on the right side and the edge of the zipper is aligned with the long edge of the fabric. Position the fabric rectangle so that the right side is facing down, and the fabric strip is on the right hand side. Pin in place. Using your sewing machine and the zipper foot, stitch in place through all layers. Refer to photo.
Step 2:
Align the other long edge of the fabric "Kulturbeutel" exterior, with the other side of the zipper and pin in place so that the right sides are facing. Take the other edge of the fabric, fold under the zipper, and pin this to the other edge of the zipper. Refer to the photo for placement, and stitch in place. It will appear that you have two separate channels, but once it is sewn in place and turned out the right way it will look like a "Kulturbeutel".
Step 3:
Open the zipper and turn the pencil case so that the fabric is on the outside and it is tubular in shape. With a pin, mark the midpoint of each side. Position the zipper so that it is in the centre of each side, and pin in place. (Refer to photo). Fold the piece of ribbon/tape in half, and position it in the middle of the pouch (linen end). Stitch along each side. Then zigzag or overlock/serge to secure. Trim ends of zipper, Turn right side out and press.
Step 4:
There you have it, a useful little "Kulturbeutel" to pop in your handbag or any other place.
