Introduction: DIY LED Panel
If you had ever made a video with any type of camera even with your cell phone you propably know how important is lighting. If you had ever work in dark place you also know that good light is necessary. I also need one but I haven't a huge amount of money in my pocket to spend for this thing, and because I love making, I made my own version of it, out of simple ad cheap parts. That's perfect DIY project for everyone, you just need some soldering, very simple one so you should do it without any problems! Soldering is not so hard so you can easily learn it from Instructables class. If you want to see video about this DIY LED panel you can check it above or here if you are in app:
So let's make a very useful LED panel for video, workshop and all of the other things where you need light.
Don't forget to subscribe to my channel: https://goo.gl/x6Y32E
and follow me on social media:
Facebook: https://goo.gl/DLmpV4
Instagram: https://goo.gl/qkm1WH
Step 1: What You Will Need?
The first thing that you will need is a base for LED strips, I used 5mm thick plywood it's 50cm wide and 35cm tall. You can use plywood with different dimensions, thats not a problem. Don't get too thick plywood because it will be very heavy.
Here is list of things that we will need, to make this project, with links to the cheapest products I had found:
- 10 meters of LED strip: https://goo.gl/FwFDuW (12% OFF Coupon: Lighting)
- About 5 meters of cable: https://goo.gl/L1x263
- Power supply: https://goo.gl/5ktHLU
- Switches: https://goo.gl/5ktHLU
- Tripod: https://goo.gl/5ktHLU (10% OFF Coupon: Elec)
You will also need insulation tape, hot glue, soldering iron and few basic tools that I am sure you have.
Step 2: Cut LED Strips
We can start by cutting LED strips to the length of our panel, remember to cut the strip in the right places (you can find small scissors on the strip, here you can cut). Don't forget to leave some space on the sides of plywood because we will solder here some cables. For my plywood I used 10 meters of LED strip so thats 2 spools.
Step 3: Fix LED Strip to Plywood
This is quite simple, but takes some time and pacient, so don't forget to play some good tunes while doing this :) As you can see I shift strips a little bit so the LEDs will shine more evenly. It looks like a chessboard. I hope you know what I am talking about :D To fix them I used a tape that is already mounted on the back of them. It holdes strongly and it should be ok.
Step 4: Solder LED Strips Together
Step 5: Break to Take a Look at Beauty of It :)
Step 6: Box for Switches
Here I just 3D print a simple box for switches with a hole for connector. If you haven't a 3D printer don't worry you can easily make it out of wood or anything you want, I am not so talented wood worker so I make one on 3D printer. Holes for switches were a little bit to loose so I fixed them with some hot glue, now it's perfect. Then we have to solder some cables to those switches. Let's start by screwing down to the connector (or soldering if you haven't a connector with screw terminals) one short red cable to + and two long cables to - we will need those cables to connect to the LED strips, and the shorter one to the main switch that will turn whole panel on or off. So now we can put our DC socket in hole and also fix it with hot glue. Short red cable from connector as I mentioned before has to be soldered to main switch, then 2 short red cables (color is not very important we just use it to show that here is the positive voltage) has to be soldered to next two switches and the second "leg" of main switch. At the end 2 longer cables to the ends of the half switches, to connect them to LED strips. When everything is ready you can use a file to make small hole for cables, and to make box lay perfect on the plywood.
Step 7: Some Hot Glue
Step 8: Last Soldering
Step 9: Power Supply
Measure output voltage of power supply it should be about 12V. If it is ok, you can connect long piece of cable to output of power supply, and other side of this cable to DC connector. Insulate everything with insulation tape. You can check out photos of how I made it, it doesn't look beautiful but it is safer.
Step 10: Mount for Tripod
Step 11: Some More Hot Glue
Step 12: Pure Perfection!
Step 13: How to Power It?
Step 14: Final Test and Conclusion
Above you can see some photos of my panel in the complete darkness. It performs great and the light is super bright. It is also useful for your home and you can use it as a lamp. You can get some great videos and photos. Working in darkness is not a problem now. It perfect project for everybody, so you should definitely try, if you made one don't forget to post a photo of it!
Don't forget to follow me, like my project and leave a comment. You can also follow me on social media:
Subscribe to my channel: https://goo.gl/x6Y32E
