DIY LED Video Panel || Dimmable and Color Temperature Adjust
Intro: DIY LED Video Panel || Dimmable and Color Temperature Adjust
Hello Internet People!!
Welcome to my first Instructable.
I'll show you guys how you can make your own Video Light/ Work Light .
Feel free to be creative and modify any steps according to your idea!
If you have any suggestions do share them with me :D.
You can watch the video here :-https://youtu.be/8DBAm4KPrzs
STEP 1: Decide Kind of Light You Want and Select the LED Strips Accordingly
For this project you can go with any of these or even any combination of these , they vary in the color temperature of the light :
- Cold white colored
- Warm white colored
- Daylight colored
Depending on your application you can go with any of these colored lights. If you want variable color temperature you can mix them up and control the brightness of each to get different color temperatures.
If you go with cold white and warm white as I did , keep the ratio of cold white to warm white to around 70:30.
If you have more warm white light's then the color at full brightness gets a little too warm.
I bought my LED Strips from Alixpress .
STEP 2: Decide the Panel , Frame and Mounting Mechanism
I went with a circular shaped LED panel . I used Embroidery Hoops/Rings as the frame for my LED panel .
I cut out the panel from a thick and dense cardboard. You can also go with a wooden panel or even an metal panel .
Metal will also help dissipate the heat better. But metal , being metal is a lot heavier and the mounts will need to be extra robust.
- Select a panel shape , Square/Rectangle/Circular
- Consider the frame and mounting before hand.
I glued two hoops of the same size using two component epoxy to increase the ring thickness . This allowed me to drill a hole and fit in a tripod screw adapter (3/8 '' to 1/4'' ). Now I can mount it to any standard tripod mount.
STEP 3: Stick the LED Strips to the Panel
- Cut the LED strip's to required lengths and paste them to the panel . You can use additional glue if the adhesive is not good.
STEP 4: Stick the Frame to the LED Panel
- Hot Glue is your best friend when it comes to DIY , but keep in mind that hot glue does not work well with metal combinations.
- You can also paint the inside of the frame white
STEP 5: Connect All the LED Strips
- Drill small holes next to the LED strip terminals , if you don't have space to route wires on the front. Also routing individual wires to the back makes the front look cleaner
- Solder thin wires and route them to the back of the panel through the holes
- If you have two colors , use opposite ends of LED strips and route them to the back . This allows you to group individual power leads better. In my case I soldered wires to one end of all white LED strips and the other end of Warm White LED strips
- Use some thick wires to solder all the LED strips in parallel . If you have two colors like I do , put them in parallel separately
- If you don't have thick copper wires , you can make one by twisting wires from an ethernet cable after removing their insulation.
- Solder the individual LED strips to respective power lines
- Solder main power cables to the ends of thick copper wires
STEP 6: Gather the Components for the Dimmer Circuit and Solder!!
Here is a schematic I created, you can build the circuit by referring to it.
This uses an LM556 for PWM signal .LM556 is nothing but two 555 timers in a single IC.
I have two different colored lights , hence two timers to control the brightness of each of them.
The PWM frequency is set to around 30KHz . Above the maximum frequency humans can hear.
Here is the parts list
1X LM556 Dual Timer
2X 47K ohm potentiometers
2X IRFZ44n Mosfets
2X 0.01uF(104) cap's
2X 1000pF (102) cap's
2X 330/220 Ohm resistors
4X 1K Ohm Resistors
1X 14pin IC Socket
PCB and connectors
12V 3A+ capable power supply
- Make sure to get good quality potentiometers
- Select a power source by measuring the current draw (atleast 3A)
- Solder the circuit according to the schematic
- Attach the circuit to the back of the LED panel and connect the power leads of your LED panel.
5 Comments
Swansong 6 years ago
That turned out really well! This would be great to use with a photo studio :)
Chinmay Shalawadi 6 years ago
RANDOM KNOWLEDGE 6 years ago
or do it like this,
dimmable and portable wireless. with camera gopro mountings.
www.wannaduino.com
WannaDuino STYLE
You can also find me on Instagram , @curio.central
