Introduction: D.I.Y. Laptop Stands
Well, laptop cooling stand is the essential thing if your laptop accidentally starts acting as an oven.. :P is fuming hot air and making the surface irritable to work with.
So here is what I had made a month ago, to help my laptop.
All the stands here are made out of MDF, a kind of wood. Made them at a friend's woodworking shop.
You could make these of different materials, maybe thick cardboard or acrylic sheet or any other material which is at your disposal.
Items required :
Important design tip :
Maximize open space while taking care of the required strength and convenience.
Items required :
- a small sheet of MDF [to build the pad]
- Band saw [to do the cutting]
- nails [to fix the joints well]
- glue [pour at the joints]
- DC Fan 12V [optional but highly recommended! :) ]
- USB cable [to connect the fan to the USB port of the laptop]
- Soldering iron
Step 1: Laptop Stand 1.0
This is the first pad that we made.
Simple, neat,easy to make! :)
- Due to the open spaces, it allowes a lot of ventilation for the hot air.
- The attachments on the front end are just to not let the laptop slip forward.
- This is a non-foldable stand
- It is a little difficult to sneak this one into a backpack.
Step 2: Laptop Stand 1.1
- We added hinges on the side joints and in the center of the base to make a foldable pad.
- It can fit into a backpack quite easily!
- We also added a 12V DC fan for faster and better cooling.
- We drilled a few holes on the chassis for more air flow.
- The fan doesn't consume much current from the laptop so dont worry! :)
Step 3: Laptop Stand 1.2 [the Minimalist Design! :) ]
This is the latest version of the board that we built.
Additional materials required for this design :
Features:
So if you too have a laptop which is in bad health, then get going and make one of these..
Happy D.I.Y.ing! :D
- Thin metal rods
- Nuts and bolts
- Small wooden cyclindrical spacers [to push inverted bolts onto those and then put the spacers on the ends of the metal rods ]
Features:
- Super light weight.
- Super sleek
- When dis-assembled, takes very little space!
Happy D.I.Y.ing! :D
![Making super delicious 'Gajar ka Halva' [Carrot Pudding]!!](https://content.instructables.com/F9R/BVOC/HCJO6OSC/F9RBVOCHCJO6OSC.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
