Introduction: DIY Li-Fi Using Arduino Uno
Very simple and useful project to understand the working of Li-Fi, you can also make your own Li-Fi device with a bit more modifications to the design and code provided. You actually need two arduino's, one to send and the other to receive to make it more fun.
Step 1: Getting Started
Components needed
100 ohm resistor,
1 K resistor,
LED,
LDR,
Arduino Uno
Step 2: Setting Up Connections
Connect one end of 100 ohm resistor to pin number 13 and the other end to the positive terminal of led, the other end of led goes to GND pin. Also connect the ldr as shown. You can also use male to female jumper wires directly for connecting the resistor and ldr.
Step 3: Setting Up Even Light
As the ldr values depend upon the surrounding light and also led cannot emit even light I have used a small paper pipe and placed the led through one end and ldr at the other end of it.
Now you are all set to start coding.
Step 4: Code
//copy this code and start modifying
int sensorPin = A0; // select the input pin for ldr
int sensorValue = 0; // variable to store the value coming from the sensor
int light=0;
int i=0;
int d[32];
int temp=1;
int k=0; int add=0;
int a=1001;//-------------- replace with any value of your choice
void setup()
{ pinMode(13, OUTPUT); //pin connected to the relay
Serial.begin(9600); //sets serial port for communication
Serial.println(sensorPin);
int b;
while(a!=0)
b=a%2; //converts binary to decimal
a=a/2;
if(b==1)
digitalWrite(13,HIGH);
delay(2);
sensorValue=analogRead(sensorPin);
d[i]=sensorValue; }
else
digitalWrite(13,LOW);
delay(2);
d[i]=sensorValue;
i++;
} i--;
// for converting binary to decimal
while(i>=0)
if(d[i]>=75&&d[i]<700)
k=i;
while(k!=0)
temp=temp*2;
k--;
add=add+temp;
temp=1;
i--;
Serial.println(add); // Final recieved value gets printed
digitalWrite(13,LOW); }
void loop()
Step 5: Further Applications
You can make few changes to the code and make it work for characters and also you can use a light bulb instead of led which can give more light evenly than the led which is the actual concept of Li-Fi.
Enjoy.
1 Person Made This Project!
- benjamincreem made it!
14 Discussions
2 years ago on Step 4
Please help mi on my email id pradip.et@gmail.com
2 years ago on Introduction
I've expanded this to use 2 arduinos. Sends data incredibly slow but it works great. Release 0.5 is for 2 arduinos. Receiver just continuously receives data from transmitter. Be sure to start the receiver first and then the transmitter. Receiver prints whatever it receives to Serial Monitor. Set up the ldr on the receiver arduino the same way that it is setup in this instructable. Setup the led on the transmitter arduino the same way that it is setup in this instructable. Transmitter sends hard coded data.
Release 1.0 includes SD cards. Setup the SD cards readers. Will likely need to change the pin number for the led on the transmitter, as the sd card will use pin 13. I used pin 8 for the led instead. Transmitter reads info file from the sd card and sends. Receiver receives the file and writes all data to its own card. Again, start the receiver first. Transmitter sends the file size, size of the file name, the file name, and then the actual file. Receiver knows when to close the file when it has written filesize bytes to the file. May create my own instructable if anyone is interested.
Code can be found here:
https://github.com/BenjaminCreem/ArduinoLifi
Question 2 years ago
Hey Hi instead of using one character.I want to interface with serial monitor.And whatever text i type it must take in and convert to decimal and detected by LDR
3 years ago
hey UdayN I would like to do this as a project...can u explain how I could transmit audio signal using the above lifi project , and one more thing is there a specific model of arduino uno that is required.Please reply as soon as you can
3 years ago
does it work the whole process
3 years ago
how can it receive data???
4 years ago
does not work..
4 years ago
how do I make it send different information? it just sends a 14 and a 0
4 years ago
oi
4 years ago
there is something wrong in the script: if i unplug the ldr, the serial monitor still shows my value "a"
4 years ago
What is the value of capacitor used ?
4 years ago
FYI, visible light is not 100x faster than radio waves. Both travel at the speed of light.
Reply 4 years ago
Yeah, it's actually the spectrum of light which is 10,000 times larger than the radio waves we use for Wi-Fi, which makes Li-Fi 100 times faster
4 years ago
Cool Li-Fi project.
