Introduction: DIY Ligthbox / Light Table
Simple lightbox/ lighttable
Step 1: Material List
- 11mm plywood
- Organic glass
- LED stripe (battery powered) with remote
Step 2: Cut Sides
Cut box sides to 11cm x 40cm size.
To do 45degree bevel cuts, used 45degree router bit (was quicker that adjust saw blade)
Step 3: Some More Cutting
Cut gap for organic glass and for bottom.
Cut organic glass to match.
Cut bottom.
Routed hole for battery cover.
Step 4: Soldering
Cut LED stripe to size, glued and soldered then
Step 5: Gluing, Sanding, Painting
Used painers tape to hold parts together - for easier gluing.
Then sanding and covering with oil.
