Introduction: DIY Longboard Press
This instructable will show you how to make a longboard press to make your own deck with a concave shape. Simply place the glued layers (learn how to make a longboard first..) of the board into the press, tighten down the bolts and leave to set for a few days. The board will then be permanently shaped.
This is intended to be more of a guideline for the design style. A lot of people have made longboards by adding weights and bits of wood about the place to try and get the shape they want. This design allows you to apply a consistent and repeatable force in the right areas to make a solid skateboard.
Step 1: You Will Need
4 x M10 threaded rod approximately 10"
12 x M10 nuts
12 x M10 washers
2x 48" - (2 1/2"x1 1/2") timber
1x 24" - (2 1/2" x 1 1/2") timber
4 x (12" - 2"x2") timber
2 x (1") packers (can be adjusted to give more or less upward curve at the end of the board
11
Step 2: Assembly and Board Creation
Once you have everything ready, it's time to make your board! I thought the best way to show this would be in video form so here are two videos, one of the press itself and the other of me building a board from scratch to show you how it works.
And that's it, this is a very simple and customisable project. Dimensions are not really critical, and you can make any size or shape of board you wish. If you have any questions then please feel free to ask. The best place to do so would be in the comments section of one of these videos and I will aim to get back to you as soon as I can.
Please support my work by subscribing to my channel if you found this useful at www.youtube.com/practicalprojects
Thank you and enjoy :)
