Introduction: DIY Macro Photography
Here are the steps I took to turn a cell phone into a perfectly good macro camera without the use of the kind you can buy on shelf. It's more fun to do it this way.
Step 1:
Step 1. You'll see that this is a lens from a film\darkroom enlarger. You can do a search on ebay for an Anastigmat lens. Here's the full name of the lens I used for this project Anastigmat Fedar Enlarging Lens 3.5" 90mm F6.3 on mounting plate
Step 2:
First, remove the plate but turning it counter clockwise. It spins off rather easily.
Step 3:
Next, remove the three screws shown here. (You'll need a small or precision screwdriver)
Step 4:
Once you've separated the parts you're going to use the second lens found screwed into the bottom half of the full set.
Step 5:
This will be the result (almost there)
Step 6:
You'll need to take this lens apart for the last time, screw the ring off of the bottom by turning it counter clockwise. You'll find a small glass lens, take it out, and leave it to the side.
Step 7:
Take the ring and super glue it to your Samsung Galaxy S3 Commuter Otterbox as shown. Press down firmly on it for about 2 minutes and let it dry over night * Don't use generic super glue, it doesn't hold. Get locktight or something along those lines.
DO NOT DO THESE STEPS WITH YOUR PHONE IN THE OTTERBOX. REMOVE YOUR PHONE BEFORE GLUEING
Step 8:
Screw the lens on the ring (now your mount)
