Introduction: DIY Magnetic Makeup Board
This is my instructable to get your make up sorted and to have everything at your disposal at one glance. Having a mishmash bag of makeup can be frustrating if you try to find something. This will end after making this.
* Thanks to my sister who inspired me to make this for her
Step 1: What You Need
Here is what you need:
- magnetic board
- adhesive magnet stripes or double adhesive tape
- small magnets
- scissors
- washi tape
- hammer
- nails
- your makeup
Step 2: Makeup
Add the magnetic strips to the makeup. If you don´t have magnetic strips you can use double adhesive tape or a hot glue gun.
When it is not possible to fix a strip to the makeup use one or two small magnet. For example for brushes I used small magnets and fixed them with washi tape (picture 2 and 3).
Step 3: Try It
Put everything on the board and hold it up to make sure that the makeup and brushes stay where they should. If something is sliding down add another magnet or stripe.
Step 4: Decorate the Board
Add a little personal touch by adding a quote, sticker or more washi tape. Put the makeup on the board and hang it on the wall. I had a board that had hangers already. If that´s not the case use nails or screws depending on the wall to fix it.
Step 5: There You Go
There you go a - Magnetic Makeup Board-
From now on your makeup will be perfectly sorted and you´ll find everything at one glance.
*Thanks again to my sister
