Introduction: DIY Mandrel Bender
Step 1: Tube Holding Blocks
Step 2: Die
I got a gear weld on blank and cut the profile of the 5/8 tube in it , using a 5/8 ball end cutter.
Step 3:
Step 4: Making a Cut Out for Clamp
Step 5:
Step 6:
Step 7: Clamp Placement
Placed clamp to see how it fits now it's ready for welding
Step 8: Prep for Welding
Step 9: Welded
I tig welded the clamp to the die using stainless steel filler rod
Step 10:
Step 11: Back in Mill
I put the welded parts back into the milling machine indicated it straight ready for the cut with the ball nose cutter
Step 12: Blended in Ball Nose Cut
Step 13: Machine Clamp
I screwed in the opposite side of the clamp to the die in the vice so I can hold it ,so I can machine it with the ball nose cutter
Step 14: Finished Machining Clamps and Die
Step 15: Clamp
I tested the clamp on a piece of .625" inch round tube
Step 16: Mandrel
To make the mandrel I'm using a piece of M8 metric threaded rod , I put two stainless screws on the end of it getting them ready to weld together
Step 17: Mandrel
After welding together I forged it with a hammer to harden it.
Step 18: Grinding Mandrel to Size
Step 19: Grinding Mandrel
To bring it to the right size and shape I put the end of the threaded rod into a drill then I sanded it on a disc sander,
Step 20:
Step 21: Finished
Step 22:
Step 23:
Step 24: Checking Fit of Mandrel
Step 25: Tube Guide
I machined a tube guide from brass
Step 26: Tube Guide
I drilled holes to mount onto a plate
Step 27: Tube Guide Support
Step 28: All Together
Step 29: Crank Handle
Step 30: Bottom of Crank Handle
I made a cut out for the tube clamp and a bored hole that locates the die
Step 31: Ready to Test
Step 32:
Step 33:
Step 34: Worked Perfectly
Step 35: Time to Make Some Parts
