Introduction: DIY Mini Rabbit Bell With Fusion Electronics
When friends talk about how for the 70/80/90 generation, if they could receive a music greeting card for their previous birthdays 🎵, That was a very happy thing. Gently unfold the paper greeting card and play the Happy Birthday song slowly. One day after the birthday, while looking at the birthday wishes on my friend's writing card again, I listened to the Happy Birthday Song. The happy birthday memories of being with my friend at that time returned, and the corners of my mouth involuntarily rose, expressing a sense of happiness and happiness. This is one of the beautiful memories of that era.
Thinking of this, why don't we create a DIY mini rabbit bell related to the Year of the Rabbit! 🐰🔔 You can stick it on the door as a doorbell or give it to friends as a birthday gift. I hope in many years, you can still recall the mini rabbit we all learned together in the spring of 2023.
There are the design steps we are going to do:
  1. Identify the electronics components
  2. Search or design the electronics libraries
  3. Design schematic file
  4. Design the outline of PCB board
  5. Route PCB board
  6. Generate Gerber or ODB++ files for manufacture
  7. Manufacture PCB board
  8. Solder components in PCB board
  9. Sharing and Fun time!
Step 1: Identify the Electronics Components
The journey of a thousand miles begins with a single step, selecting the necessary components according to your design needs. The mini rabbit PCB circuit board we are sharing today will use the following components.
  • Resistor 220 ohm, R1, R2
  • Resistor 1000 ohm, R1K
  • LED1, LED2
  • 1220 Battery + Battery Holder
  • Triode, S8550
  • Switch, S1
  • Buzzer
  • Triode, T1MUSIC FOR ELISE
The BOM list is attached for your reference.
Step 2: Search or Design the Electronics Libraries
You could search the library you want to use in Fusion Library Manager or using the Fusion add-ins (SanpEDA or UltraLibrarian) from Fusion App Store, or create the library by yourself. Here we provided the library and the corresponded 3D Model for your usage if needed.
Please following the steps to create the library which has 3D Model in Fusion.
1. Upload "RabbitCircuit.flbr" to Fusion
2. Upload all 3D Model files to Fusion
3. Open the uploaded library in Fusion
4. In Content Manager panel > Switch to Footprint panel
5. Right click the footprint > e.g. CR1220
6. Create New 3D Model > Save The File to the destination you want to save the linked 3D Model in later.
7. In Fusion Data Panel > Right click the uploaded 3D Model in step #2 which named CR1220 > Select Insert into Current Design
8. Click OK button
9. Click Finish button in the toolbar
10. Save Changes > OK to save changes
11. Then you will see the 3D Model is added for the footprint and device.
Step 3: Design Schematic File
Create Fusion Electronics File > Create Schematic file > Add devices from library > Connect nets for the schematic file.
Here we attached the f3z file which included the schematic, 2D PCB and 3D PCB for your reference.
Step 4: Design the Outline of PCB Board
Switch from schematic file to board file, you will get a rectangle board file with the devices outside of the outline by default. But the key point for this project is the PCB board outline, so we delete the default rectangle board file, and then use Insert DXF/DWG function in Fusion Electronics to get the expected board outline.
We inserted the attached Rabbit.dxf which got from others and not selecting the layer 0 in the Inserted DXF/DWG dialog, then we could see the PCB board outline is a Rabbit!
This is a very helpful function in Fusion Electronics to create an interesting PCB board as you want.
Step 5: Route PCB Board
Drag the devices to place in the position you want they are in the board, then route the wires.
Additionally, we draw the circles for Rabbit eyes on 21 tPlace layer to make it looks better.
Finally, add polygon pour for the board.
Later Push to 3D PCB to get the result, if you want to see the 3D PCB board.
You could also change the soldermask color and others in the CAM Preview dialog and then push to 3D PCB again you will see the updated one.
Step 6: (Optional) MCAD and ECAD Integration
You could skip this step if you want to try MCAD and ECAD integration in Fusion currently later. It's very easy for Mechanical and Electronics engineers working in the same platform by leveraging the Create In Place function without data exchange problem.
  1. New Fusion 3D Design
  2. New Sketch
  3. Insert DXF we provided into the Sketch, uncheck the layer 0 in the Insert DXF dialog
  4. Finish Sketch
  5. Create PCB > Create linked PCB > Click OK button when pops up dialogs, which will enter into Edit in Place environment
  6. Click Define Board command from toolbar
  7. Select the outline to define the board
  8. Linked to the saved 2D PCB board file which hasn't been linked with 3D PCB yet (Please note: In "step 5 - Route PCB Board", if you have pushed the 2D PCB board file to 3D PCB file earlier, then you need to break link of the 3D PCB file for that 2D PCB firstly > Save the 2D PCB file and then try this step here.)
  9. Save and Continue
  10. Select the saved 2D PCB board file (without linked 3D PCB file) to link it with the newly created 3D PCB file
  11. Push to 3D PCB
  12. Finish the Edit in Place environment
  13. Save the files
Till now, the sketch created in Fusion 3D Design is be used as the outline of the PCB board.
Modifying the sketch in Fusion 3D Design > Save the file, then in the 3D PCB, we could see there is indicator to remind you the reference file is updated, click get to latest will get the updated outline. It means the change in Mechanical design will be updated by one-click button in 3D PCB directly, After push to 2D PCB from 3D PCB, then the board outline is updated too.
Step 7: Generate Gerber or ODB++ Files for Manufacture
When the board file is finished, you could generate Gerber or ODB++ Files for manufacture.
Send the Gerber or ODB++ files to your manufacture and wait for your boards.
Step 8: Manufacture PCB
After several days waiting, we received the sample PCB board from manufacture.
We ordered 3 colors.
Step 9: Solder Components in PCB Board
Solder components in PCB board ~~~
Such a cute Rabbit, isn't it? :)
Step 10: Sharing and Fun Time!
Hope you enjoy!
Step 11: Acknowledge
  1. Fusion Electronics Design - Richard Liu
  2. PCB Manufacture and Solder - Panpan Fan, Jackie Chen
  3. Article and Images - Helen Chen
