Introduction: DIY Motorized Engraver
Make your very own Hand held motorized engraver with simple household stuff
Step 1: The Materials You'll Need:
The materials you'll need are the following
pvc pipe
DC motor
sand grit paper
small metal rod
toothbrush
wires
2pcs. alligator clips
12V voltage source (Variable Voltage Source)
pliers
cutters
Glue stick
lighter
Step 2: Now the Main Component:
In order to make the engraver, do the following steps
first: cut off the toothbrush as shown
second: cut off the metal rod into a 1 inch length
third: Scratch the metal rod using a cutter or any means of making the tip rough enough
fourth: Heat the metal rod while using the pliers to hold it and put it gently in the cutoff toothbrush.
and now you have an engraver of your own
Step 3: Now the Circuitry:
Take the DC motor and connect the wires and put alligator clips at the end of each wire
attach it into the pvc pipe using glue stick fortify and strengthen it all up.
Step 4: And Now You Have It:
Your Very own Motorized engraver
Connect it to a power supply and ready yourself for the engraving.
Step 5: You Can Engrave Anything!
You can engrave anything!, from glass, metal, plastic, wood, ceramic, almost anything!... not on cloths though and human skin... in case you want blood in your skin....
well, so much for that Engrave and Enjoy!.
