Introduction: DIY Multi-Room Audio
Hey! everyone My name is Steve.
Today I'm going to show you How to Make a Wifi Audio Streamer using very fewer parts and it's better than chrome cast Audio and you can use it as multi-room setup and it can connect up to 10 Speakers
Let's Start
Step 1: Features
Input Power
- 5V DC
Output Power
- 2 X RCA for Stereo Audio Output
Step 2: Thing I've Used
LCSC
- DC Socket - http://bit.ly/33RkqBF
- Stand-Off - http://bit.ly/2z8qpDU
- RP-SMA Female Jack - http://bit.ly/2z8qpDU
- 3db antenna - http://bit.ly/2z8qpDU
LCSC 8$ OFF on your first order - https://lcsc.com/?href=STEVE&source=referral
Banggood
- Up2Stream WiFi Module - https://goo.gl/wLck2Q
- Aluminium Case - https://goo.gl/wLck2Q
- PCB Stand-Off - https://goo.gl/wLck2Q
- Heat Shrink Tube - https://goo.gl/wLck2Q
- RCA Connector - https://goo.gl/wLck2Q
- Rubber Pad - https://goo.gl/wLck2Q
- Drill Bit - https://goo.gl/wLck2Q
- RP-SMA Female Jack - https://goo.gl/wLck2Q
Amazon
- Up2Stream WiFi Module - https://amzn.to/2xo57kg
- Aluminium Case - https://amzn.to/2xo57kg
- PCB Stand-Off - https://amzn.to/2xo57kg
- Heat Shrink Tube - https://amzn.to/2xo57kg
- RCA Connector - https://amzn.to/2xo57kg
- Rubber Pad - https://amzn.to/2xo57kg
- Drill Bit - https://amzn.to/2xo57kg
Aliexpress
- Up2Stream WiFi Module - http://bit.ly/2WZgs5H
- Aluminium Case - http://bit.ly/2WZgs5H
- PCB Stand-Off - http://bit.ly/2WZgs5H
- Heat Shrink Tube - http://bit.ly/2WZgs5H
- RCA Connector - http://bit.ly/2WZgs5H
- Rubber Pad - http://bit.ly/2WZgs5H
- Drill Bit - http://bit.ly/2WZgs5H
Note - Please see the images for better understanding
Step 3: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 4: Marking & Drilling
- I Used a Philips Head Screw Driver to Open the Enclosure
- And Then I placed the Up2Stream module on top of the Enclosure and used a Center Punch to Punch 4 Holes
- And then I used a 3mm Drill Bit to Drill the Punches
Step 5: Marking & Drilling Back Panel
I used Center punch for marking of 2 RCA Jack, DC jack and wifi antenna
and then i've drilled 4 holes with a drilling machine
Step 6: Install
- First, I've installed DC Socket
- And then I've installed 2 RCA socket
- And then I've installed Wifi antenna socket
Step 7: Stands Off
I used 4 stands off to give it some clearance
Step 8: Wire Assembly
This board comes with 2 wire one is audio output wire and one is power input wire
The problem is the audio output wire has 4 wire and you only need 3 wire one for Right channel output one for Ground and one for Left channel output,
The fourth wire is WPS you don't need it
So, I've cut the forth wire
Step 9: Enclosure Assembly
- First, i've connected the wifi wire to the board
- I used 4 screws to fit the board into the enclosure
Step 10: Soldering
- First I've soldered the 3 wires to the RCA socket
- And then I've soldered the 2 wires to the DC socket
Step 11: Final Assembly
- I used 4 screws to fit the back panel
- And then I used 4 screws to fit the front panel
Step 12: Rubber Feet
I used some rubber feet on the bottom
Step 13: Connection
Connection
- First I've connected the RCA Jack
- Second I've connected the 5v Dc Jack
- Third I've connected the Wifi Antenna
Speaker
- I used my Bluetooth Speaker as my Speaker output Via Aux input
Step 14: Setup
- You need MUZO App to setup
- Open MUZO App Select " Add another MUZO compatible speaker "
- Select BUSH
- Select Setting
- Now connect to "Stream System"
- Now select the Wifi you want your speaker to connect and enter the Password
- Now you can keep your speaker Name
- You are all Set
- Now go to My Music
- And Play the Song
- You can control Your Volume There
- You Can connect up to 10 Speaker and can play different songs
Enjoy
Step 15:
Thank you for visiting my Instructables Stay tuned for next Projects
