Introduction: DIY Nespresso Capsule Holder
Hello and welcome to this instructable.
You can create your own design in inkscape or use the one provided
1 x Fablab, or access to a lasercutter
1 x 300mm wide 600mm long 3mm plexi
Step 1: Start Cutting
Your lasercutter should be configured to CUT red lines and Engrave BLACK. The material should be configured to be 3mm plexi
Step 2: Assembly
Remove the correct parts from the lasercutter and assemble.
You can glue the parts together using specific plexi glue.
Step 3: Enjoy
Enjoy!
Step 4: Improve
1) When buying caps they come in boxes of 10. The Design should be modified to hold 10 caps per row
2) Base text: the text is not centered and also doesnt make sense because you cant read it when filled with capsules
3) Base: Either make the base larger so it supports the weight better (but seems fine for now) or change the design to brackets.
4) Sides: Change the design so it has sides; this will help stability
