Introduction: DIY Off the Shoulder Crop Top Sweatshirt (No Sewing)
Turn a basic crew neck into a cute off the shoulder crop top sweatshirt in no time!
Full video tutorial: https://www.youtube.com/watch?v=O7yZq7xxAJk
Step 1: Gather Materials
What you'll need:
- Crewneck sweatshirt http://amzn.to/2DLgQLT
- Ruler
- Fabric scissors http://amzn.to/2lpapZM
- Pencil or colored pencil
- Fabric glue http://amzn.to/2qor51E
- Elastic http://amzn.to/2EWZEa5
- Needle & thread
*Miaira is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to Amazon.com.
Step 2: Try on & Mark
First, put the sweatshirt on and use your pencil to mark where you want the bottom of the crop top to be when it's done. I chose to mark right above the belly button.
You don't have to mark the top of the sweatshirt because you'll just be cutting right under the collar.
Step 3: Cut Top
Take the sweatshirt off and use your ruler to draw a straight horizontal line across the top of the sweatshirt, directly under the collar. Then cut along the line.
Step 4: Cut Bottom
Place your elastic directly under the spot that you previously marked at the bottom of the sweatshirt. Then use your pencil to mark another spot right under the elastic. Next, use your ruler to draw a horizontal line across the bottom of the sweatshirt at the lowest mark you just made and cut it.
Step 5: Cut & Glue Top
Flip the sweatshirt inside out. Place elastic along the top edge of the sweatshirt and cut a slit at each shoulder of the sweatshirt that is slightly longer than the width of that elastic, as you will be folding this material over later on when it's time to glue. These slits will make it easier to fold later and will also be used to insert the elastic.
Squeeze a good amount of fabric glue (but not too much) along the entire top edge of the sweatshirt. Then, fold the top edge over and glue it down, making sure that the space in between is wide enough for the elastic.
Step 6: Cut & Glue Bottom
Repeat this process at the bottom of the sweatshirt, placing the elastic along the bottom edge and cutting slits at either side of the sweatshirt that are slightly longer than the elastic's width.
Glue along the edge, fold it over and press it down, leaving space for the elastic later on.
Step 7: Measure Elastic
While the sweatshirt dries, take your elastic and measure it by wrapping it around your shoulders and waist. Cut pieces as needed.
Step 8: Insert Top Elastic
When the glue has dried, secure a safety pin (in this case I used a paperclip because I couldn't find a safety pin) at the end of the elastic you cut for the shoulders and insert it into one of the slits at the top of the sweatshirt. Then use the safety pin (or paperclip) to work the elastic all the way around the top.
Step 9: Sew Top Elastic Ends
Once the elastic is all the way around, use your needle and thread to secure the ends together.
Step 10: Insert Bottom Elastic
Repeat this process at the bottom of the sweatshirt, inserting the elastic and working it all the way around, then hand sewing the ends together. Flip the sweatshirt back to its right side and you're ready to go!
Step 11: All Done!
You now have an off the shoulder crop top sweatshirt that's cute, comfortable and can go with sweatpants, jeans, shorts and more. Let me know if you try this tutorial out! :)
YouTube: https://www.youtube.com/miairajenningstv
Instagram: https://www.instagram.com/miairajennings/
Twitter: https://twitter.com/miairajennings/
Blog: https://twitter.com/miairajennings/
Website: https://twitter.com/miairajennings/
