Introduction: DIY Origami Heart Box- Secret Message (easy
This simple heart origami box is pretty cool- once opened it reveals a secret message!!
Step 1: Preparation
Fold square paper in half (colour or pattern facing down) on both diagonal axis. Cease well and unfold.
Step 2: Beginning the Project
Fold all corners to the centre, crease well and unfold.
Step 3: Folding In
Turn the paper over, fold top and bottom corners 'till crease line.
Step 4: Repeat
Fold top left and bottom over existing crease line.
Step 5: Adding Text
Write message in the box shown above. When the person opens the heart later, it will show the message u will write. Fold top left and bottom right to meet in the centre
Step 6: Horizontal?
Turn the paper so it's horizontal
Step 7: Point ADBC
Fold point A to point C. Crease well and unfold. Then fold point D to point B. Crease well and unfold.
Step 8: The Tricky Bit
Make 2 diagonal folds as shown bellow
Step 9: AGAIN the Tricky Bit
Fold the right tip over to the left tip. Press paper down
Step 10: Nearly Half Way...
Fold the top and bottom tips to the centre. Crease well.
Step 11: The Left Tip
Fold the other tip to the right. Crease well.
Step 12: Half Way...
Now make a vertical fold, making the top layer over to the right edge.
Step 13: Repeating
Now turn paper 180 degrees. Repeat steps 8-12
Step 14: Forming the Heart
Fold bottom two corners in to make the bottom of the heart. Crease well. Then, make a smaller fold at the top left and top right to create the top of the heart. Measure from where you just folded about 2mm and snip from there to the centre.
Step 15: SORRY...
I'm sorry if this was hard to follow. As you can imagine it is quite tricky to explain I just thought I had to share it with you guys. If you couldn't make this, put it in the comments and I'll try my best to explain the part you got stuck on. Thank you :) my next instructables will probably be another origami or a rainbow loom creation as I have quite a few that I'd like to share. Sorry again
Spaceofhearts
Spaceofhearts
