Introduction: DIY Origami Lamp
This is an easy DIY wooden lamp with changeable paper origami shades.
Step 1: Making Parts of Wooden Frame.
The size of the lamp can be according to your liking or space.
The dimensions of wooden pieces I have used for the frame are (w x d x l) :
15 x 7 x 380 mm - 4 pcs
15 x 7 x 230 mm - 8 pcs
7 x 5 x 350 mm - 4 pcs
Take a suitable piece of teak wood or any other preferable type of wood and cut them into pieces.
Use a band saw or a table saw to cut the pieces in dimensions.
The wood I have used is teak wood and I took it from a old furniture piece.
Step 2: Sanding.
Sand the wooden parts with a rough and a smooth sand paper until you get a smooth finished surface. The sand paper I have used is of 60 grit to remove excess material and 220 grit for smoothening it.
After sanding it by hand you can sand it on a sanding machine with a fine grain sanding belt on it to achieve a final finish.
Step 3: Assembly
- Paste the pieces of wood with a strong adhesive to make a cuboidal frame as shown in images above.
Step 4: Sanding and Lacquer
After pasting the pieces together leave it to dry for a night and give it a final hand of sanding to give it a finish look. Make sure no glue stains are visible.
Apply first coat of lacquer and let it dry and sand it very lightly and then apply second coat of lacquer to give your frame a final finish.
Step 5: Putting MDF Base.
Paste 4 small MDF or wood pieces on its base and keep a MDF base with a centre hole in it on those 4 resting pieces.
Step 6: Putting Metal Plates
Put iron plates on inner side of the wooden frame. The position of iron plates should be on the corners of each rectangular frame. Stick it with araldite or any strong adhesive as shown in images above. Total 16 pieces of iron plates were used.
Step 7: Origami Shades
Use any translucent thin paper to make an origami paper shade
I have used a rice paper and made a hexagonal tessellation origami out of it. You can find videos of how to make it on youtube or you can refer to Eric Gjerde's book named Origami Tessellations.
Step 8: Attaching Paper Shades and Bulb.
Paste the origami tessellation on a rectangular plane sheet. Place the corners of paper shades on the metal plates and put magnets on them.
The panels are changeable. You can change the paper shades and try different origami tessellations patterns on the lamp.
Attach bulb holder and a 15W off-white LED bulb inside.
