Introduction: DIY Outdoor Wood Bench
With summer underway, I set out to transform my small 5 ft x 9 ft balcony into an intimate al fresco dining area able to seat 4 to 5 people. Having that many chairs on such a small balcony would have been cumbersome, so instead I decided to build simple wood benches to make a corner booth. I didn't want anything too complicated to build so I came up with a very simple design that only takes a couple of hours to make using basic tools and materials.
I'll walk you through how to make one of them and then you'll be able to customize the design to work with your outdoor space. You can also watch the video where I show how I made the benches (you can fast forward to 3:28 min)
Bench dimensions: 56" long x 16 1/4" wide x 17 3/4" high
Materials needed: 6 x 1" x 4" x 6 ft pine boards (~ $4.50 each), 1 x 2"x 3"x 6 ft stud (~$2.00), weather proofing stain or paint, decking screws (1 1/4", 2")
Step 1:
Cut the pine boards and stud to size (I had mine cut at the hardware store):
Cut list:
Frame (1"x4"): 2 x 55", 3 x 13 3/4"
Top (1"x4"): 4 x 56"
Legs (2"x3"): 4 x 17"
Step 2: Paint or Stain the Wood
I stained the wood using a semi-transparent weather proofing stain from BEHR (coffee color) and applied 2 coats. For a small project like this, an 8 oz sample is more than enough.
Step 3: Build Frame
Use corner clamps to hold the pieces together (adding wood glue before doing this will make the joints stronger but skipping the glue will allow you to easily disassemble the bench later). Drill two pilot holes and put in screws (use 1 1/4" screws). After the four sides are put together, add the middle piece for extra support.
Step 4: Attach Top
Place one of the top 1" x 4" on top of the frame so that it extends 1/2" past the edge of the frame at the ends and on the sides. Drill pilot holes and screw in place.
Screw in place the remaining pine boards, using a scrap piece of 1" x 4" as a spacer.
Step 5: Attach the Legs
Using clamps, secure one leg to the inside of one corner of the frame. Then drill pilot holes and screw in place (use 2" screws).
Step 6: Completed Corner Booth With DIY Wood Benches
Here is the finished project, after I added cushions and built privacy panels to complete my corner booth DIY outdoor dining area (you can see how I built the privacy panels in this video). I love how my DIY al fresco dining area turned out and it's been a wonderful place to enjoy warm summer evenings with friends and family.
Second Prize in the
Weekend Projects Contest
Great Outdoors Contest
5 People Made This Project!
- Lduque2020 made it!
- whitney.payment made it!
- vanowen made it!
- claytonjwalsh made it!
See 1 More
41 Comments
8 months ago
Hi there,
First of all, thank you for posting this. I've been looking for something like this for a long time, I'm glad I came across this. This may be a silly question, but how big is the spacing between your 1x4s on the top? I assumed you were using a 1" spacer, but then the width doesn't add up for me. Was your spacing more narrow?
9 months ago on Step 6
Very easy to make. I just changed the legs to 4x4 just to create some extra weight, and I made the one much longer for the space I wanted.
Reply 9 months ago
Love it! Thanks for sharing!
1 year ago
Let's check stodoys ebook if you want to make it cheaper and better.
5 years ago on Introduction
That is a great looking bench
Reply 5 years ago on Introduction
Thank you!
6 years ago
built these three other weekend, great instructions. I was able to make them in just under an hour each.
Reply 6 years ago on Introduction
Your benches and balcony look amazing!! Thanks so much for sharing!
7 years ago
I can't wait to build these! Once it warms up a bit, that is. :p Question: what kind of drill do you have? I'm wondering how much drill I'll need for some fun basic projects, and if cordless would be powerful enough, too. This will be my first project! Very excited to use the table saw I got in the fall, too.
Reply 7 years ago
I use a Dewalt cordless drill (DCD710) and I love it! It's light weight and has more than enough power for all the projects that I do. And the Lithium ion battery lasts a long time. Have fun with the project and I hope you'll share pics when it's done!
7 years ago on Introduction
gorgeous! i need this for my balcony! btw, what do u think the weight limit on this would be? I come from a family of rather "heavy" gals... i don't want us all to fall over when I have girls night! haha :)
Thanks! I'm not sure what the exact weight limit is but I've had 2 average sized adults sit on the benches without any problems. You could always add some more cross-bracing to the top of then bench and more screws to the legs to make the bench extra sturdy!
7 years ago
Lovely benches !
Reply 7 years ago
Thanks!
7 years ago
That is amazingly simple and beautiful. In fact I am going to get supplies for it now.
Reply 7 years ago
Thank you! Hope you'll share pics of your benches!
good job
how many screws did you use in the bench?
I used 8 x 2" screws and 36 x 1 1/4" screws
Hey congratulations on being a finalist in the weekend projects contest!
