DIY PBC Vertical Garden
Intro: DIY PBC Vertical Garden
Create a very Beautiful, and Space Saving Vertical Garden From Recycled PBC Pipes
STEP 1: Lets Get Started
Gather all Needed Materials
You will Need
PBC Pipe with Desired Size
Round Plastic Container that must be fit to plug PBC pipe bottom
Tape Measure, Pentel Pen
Sanding Paper, Metal Saw
Gas Stove, or any Heating Source, Kitchen Gloves
STEP 2:
Measure/Divide Vertical spaces of PBC as Desired and Mark by Pentel
STEP 3:
Measure Desired Slit Length Depending on PBC size, Slits must be done alternately
STEP 4:
Start Sawing all Marked Slits using Metal Saw
STEP 5:
Carefully Soften Area above slit using Stove or Heat Gun, Form a Fist using Kitchen Glove and punch soften area carefully to Create Crevice, Finish all Slits.
STEP 6:
Smooth all rough surfaces using sand paper
STEP 7:
Use the Plastic container to plug PBC bottom press firmly to fit
STEP 8:
Finally Level and fill with garden soil, Enjoy planting...
2 Comments
agundrum 8 years ago
Don't you mean PVC (poly-vinyl chloride) pipe?
A pretty cool idea. I would wonder about stability after a certain height. You could cut a piece of flat material (plywood or something water resistant) that is double the diameter of the pipe then center and attach the pipe to it. I think there are pipe plugs/caps that
