DIY PSU Into Bench Power Supply
71,729
164
81
Introduction: DIY PSU Into Bench Power Supply
About: Always loved electronics. I like to reuse parts or componets and I Love to be part of the Instructable community.
This is my bench power supply made out of an PSU. Any questions....? I'll be glad to help.
And here is the schematic.. (in the schematic there is a mistake, the USB should be connected to ground an +5 instead of -5)
https://www.instructables.com/files/orig/F88/8JHO/FSSIQIA5/F888JHOFSSIQIA5.pdf
And here you can see a graphic schematic.
https://www.instructables.com/files/orig/F2D/LMFU/FYYNECNH/F2DLMFUFYYNECNH.jpg
1 Person Made This Project!
  • Micro:bit Contest
    Micro:bit Contest
  • Plastic Challenge
    Plastic Challenge
  • Back to School: Student Design Challenge
81 Comments
denojorim
denojorim
3 years ago
how did you manage to connect both the multimeter wth the PSU, realy cool idea. kindly explain.
ccronkhite
ccronkhite
5 years ago
So... I put together the variable voltage circuit on my breadboard, hooked it up to the pos and neg 12V of my power supply. Turned it on and it was putting out about 22V at first, then as I started to turn the potentiometer, the pot went up in smoke. The pot that I got was rated at 5k with a power rating of 0.5watts. I'm assuming the 0.5w is not high enough. Anyone know the minimum rating that is needed for this? My initial guess would be to calculate the watts coming out of the -12V lead on the power supply and use that as a bare minimum.
Drillbit
Drillbit
7 years ago on Introduction
Any plans on posting a step by step for this instructable? I do hope you do, I would like to build one just like yours to test with Halloween props.
newtonn2
newtonn2
Hi there! I don't have this power supply anymore. Did you check my other power supply instructable?
Drillbit
Drillbit
I have, I still like this one the best for the ideas I have for it. If you do make another I would love a step by step. Working on a low voltage haunt and these would be great.
laiskasmariui
Hi, I've build a similar unit, but when i try to draw more current it shuts down. The most current i saw om my meter was around 500mA, on the PSU itself it says: 16A at 12V, 13A at 5V and so on. Have you any idea where the problem could be?
Thanks.
Hatredman
Hatredman
Maybe the load resistor you're using is too low, so it drains more current than it's needed.
imonfyre
imonfyre
8 years ago on Introduction
Hi there, I have was just poking around for some power supplies conversions, and yours looks very nice. A question, though... Is it possible to get 15v out of your set up by combining the -12v and the +3.3v?
tariqshan
tariqshan
Nice work, i have a question about this psu from dell NPS-330CB C well i did some search on net for pinout it turned out that grey wire is for PWR-ON ok short it with which wire to switch it on. yes switching is main problem help needed.
hmorton1
hmorton1
9 years ago on Introduction
Hey there, very nice writeup.. please tell us when will you update your new instructable for the new Bench Power supply?
newtonn2
newtonn2
Hi there! The instructable of my new bench power supply is on line an running, see it here
https://www.instructables.com/id/Make-a-bench-power-supply-mostly-from-recycled-par/
seanksg
seanksg
Is there a specific type of relay you used for this?
jkotecki
jkotecki
Great project!! I have one question though. You show the connections for the USB charger port connected to -5v and GND. Should that be +5v instead?
newtonn2
newtonn2
Ups! Thank you for pointing that out, it is a mistake of course. You need to connect the usb to Ground and +5. Sorry about that.
jkotecki
jkotecki
I have one more question. On your schematic what is the switch actually connected to other than ground?
newtonn2
newtonn2
It's connected to the green wire. That switch will turn the PSU on.
brusho150
brusho150
I donot have green wire on my atx power supply. What to do please help!
Kandeman
Kandeman
Thanks for this circuit, I've had fun putting it together but have a small problem. I can only get a touch over 12.3v across the regulated output (LM350K). I've double checked the circuit and confirmed that I have 23v across the input (ceramic capacitor). Can't quite work out what I've done wrong?
