Introduction: DIY PVC Backdrop
About: Yes. Citizen of heaven. John 3:16.
This PVC Backdrop is perfect to pull out for any event. I recently used this for a Valentine Banquet, and now it's being used for my friends wedding! When we were setting it up I got a few pictures and I'd love to show you all how to make one as well.
2 - 8' PVC
2 - 4' PVC
2 - 3' PVC
4 - 2' PVC
2 - 1' PVC
2 - Elbow Fittings
4 - T-connecters
Step 1: The Base
Connect 2', T-connector, and 1' pipe together. Repeat.
Step 2: Working Upward
Now use your 4' piece and place them into the last opening of the T. Repeat on other side.
Step 3: Working Up Continued
Now place another T piece on top of the 4' piece with the open end facing inward. Repeat on other side. Then place your 8' piece in between your two T connectors.
Step 4: Taller Yet!
Now get your 3' piece and place an L bracket on one end, place the other end on top of the T bracket. Repeat on other side.
Step 5: All the Way to the Top!
Now, use your remaining 8' piece and put it at the top using the L brackets. (Step stool recommended)
Step 6: Curtains!
Before you place your last 8' piece on top be sure to put some curtains on it as well as any kind of decoration you want for you event!
Step 7: Greenery!
Don't forget the final touch! We used Ivy to make this back drop look breathtaking! But you can use any kind of greenery etc. that you want!
Step 8: Tips and Tricks
In the 'Supplies' step, there are two pipes that I 'X'ed out, I used those pipes to stabilize my frame a little more, this step is optional.
