DIY PVC Speaker
Intro: DIY PVC Speaker
Hi, yet another pvc project.
This time im with an cool pvc speaker .Recently i made an powerful 7.1 and there where lack of an center speaker
so i decided to make an center speaker with pvc's,
please go threw pictures and ask me if you have questions.
STEP 1: Parts Needed
Here im using all 75mm(2.5 inch) pvc.
- length (for joining elbow to T)
- 2 - elbows
- 1 -T
- Reducer
- 1 - Tweeter speakers
- 2 - Speakers (i used 10w)
- Any epoxy compound
STEP 2: Preparation
First make two holes for air vents and fix a small piece of pvc pipe this will results clean bass.
And make another small holes for speaker wire
Then glue speakers and seal the remaining gaps with epoxy
STEP 3: Finalizing
Do speaker connection ,(i made this speaker as center speaker for my home made 7.1 system so i connected those
3 speakers in parallel )
Then assemble everything together ,paint it it you want.
STEP 4: Result / Other Stuffs
Seriously result is just amazing, sound is crystal clear "especially vocals " air vents on back are really working well
getting good mid volume thats good for center speakers.
So i started few more pvc speakers projects
TRY IT AND ENJOY!!
21 Comments
AndriusŽ1 6 years ago
Hi, nice work, have you tried to make calculations for volume and resonance tube?
chrisjlionel 8 years ago
You've connected 3 speakers in parallel. Maximum how many speakers can be connected in parallel. Is there any calculations?
nielsb2 8 years ago
great instructable! what input did you use?
tominjose 8 years ago
o\p from desktop.
joel.munoz.7547 8 years ago
Nice job mi amigo! I'm going to try and track down some Bose brand speakers to add the my PRO Klips 7.2 with 8 bass shaker setup. I'm looking for that extra high, crystal clean sound and my system would be better than the Omini set up. Thanks again!
Gracias! All the best!
tannerg02 9 years ago
Thinking about making one of these, though I will probably add bluetooth and maybe make it waterproof
nguyennguyen235 9 years ago
I like your idea
tominjose 9 years ago
Thank you!
iam_maker_leo 9 years ago
Great idea and Great one....
I will try it...
Thanks!! all the best :)
SuperPollo 9 years ago
I am thinking of doing a pvc speaker as well, but not yet. So I am collecting ideas and tips for speakers, and since I started, all the DIY speaker are seal tight without air ventilation, because they said it made a better sound, but now I see your's and I have to ask. Should I put air ventilation? Why? I mean I don't get how it works to improve the sound.
THANKS
Even i had that same doubt . so i tried both with and without vents ,for me with vents sounds better .(will give more mid and low frequency )
And dont put simply holes as vents ,insert an small pvc as shown in image.
http://www.hometheaterhifi.com/volume_5_2/cmilleressayporting.html
Thanks for the reply, but as you can see above, my enclosure is not made to have air ventilation, so I probably won't put them. Maybe in another project, I wish. Thanks for the info anyway =)
Thanks mate, I think I won't need the air ventilation, because i got the speakers from a base without air ventilation. Plus, the body I have for my project isn't big enough to let the air reach the cone from the back.
Thanks again, and if I feel like I need answers, I'll do as you say and post it in the questions =D
NoleCzar 9 years ago
Where did you get your speakers from and what size are they?
I brought it from a shop ,its 3inch woofer speaker
MsSweetSatisfaction 9 years ago
That is so awesome, and so much cheaper than the store bought ones!
tmcheema 9 years ago
gracias
