Introduction: DIY PVC Tripod
Things that you will be needing:
1. 1" pvc pipe X 2.5ft
2. 1/2" pvc pipe X 5ft
3. 1" pvc cap X 1
4. 1/2" pvc cap X 5
5. 1/2" pvc cross T X 1
6. small nuts & bolts X 2 (don't know the exact measurements, but it should be of the size co that your camera should
be secure)
7. large nuts & bolts X 2
8. Epoxy
9. power drill
First, cut 1/2" pvc pipe with length measurements:
6" length X 4 ( for its base )
3ft length X 1 ( remaining )
Then, take 1/2" cross T & 1" cap, Drill a hole in the centre of the cap & cross T & fix them together with the small nut and bolt.
Take 1" pipe and drill a hole in the upper part of the pipe. Hole should be of the size so that the nut would fix in the hole. Secure that bolt using epoxy.
Take 1/2" cap, Drill a hole in it, enough that you could secure a small nut & bolt in it.
Attach the base legs, ( Fix them if you want to.. using pvc glue )
And YOU are done!!
3. 1" pvc cap X 1
4. 1/2" pvc cap X 5
be secure)
8. Epoxy
9. power drill
And YOU are done!!
