Introduction: DIY Pallet Wood Floor (+video)
In this Instructable, I go over the steps I took in creating this bright floor in our school room.
I used pallet wood palings and non-structural pine. Cheap chip board screws and poster paint to color.
This floor has been in, for well over a year now and is in the high traffic zone of our house (horse shed).
It has held up really well and still looks great.
Made from . . .
- Recycled pallet palings.
- Non-structural pine.
- Chipboard screws.
- Poster Paint.
Step 1:
Start by cutting and pulling apart some pallets.
Step 2:
Run the circular saw down either side of the pallet.
Step 3:
Flip it over and do the same for the other side.
Step 4:
Twist and rock the palings back and forth then leaver them off with a pry bar.
Step 5:
Hammer out all the nails.
Flip it over and use some kind of chock to remove them.
The kids love helping with this part.
Step 6:
3 pallets worth of palings make quite a nice starting point.
Step 7:
If you have a thicknesser, then you can run all the palings through that, just to clean then up a bit.
But if not, you could use an eighty grit flappy disk on the angle grinder and a 120 grit on the sander.
Step 8:
Decide were you want to put your floor and what direction you want the floorboards to run.
Step 9:
The edge frame of the floor is attached into the concrete using
a masonry drill bit and plastic plugs.
Step 10:
The rest of the pieces are just resting on top of the ground.
But to prevent them from being kicked out of position by my kids,
I attached them either end using pocket holes.
Step 11:
This isn't exactly how you are meant to use this jig,
but I don't have the rest of it and this works just fine.
Step 12:
To save on both space and money.
I run the lengths of 70x35 down the table saw to rip them half.
Step 13:
For the pallet palings, I first square up one end.
I do this by running the circular saw along the speed square.
Step 14:
Mark the length and were you want the screws to go.
Step 15:
Take it back out side, and cut it to length.
Step 16:
Pre-drill and chamfer the holes.
Thanks to dad, I now have a counter sink drill bit to both of those jobs in one go.
otherwise you can just do one and then the other.
Step 17:
If you want to add a bit of extra character, you can vary the widths of the boards.
I did this by running the palings down the table saw.
I picked 45mm, 90mm and 140mm for my varying widths
Step 18:
When you have all the pieces cut, it is time to paint them. I am using cheap Poster paint.
Step 19:
And then slap on some paint. I gave each board 2 coats each.
Step 20:
Attach the boards to the floor frame,
using 35mm chipboard screws. (because they are affordable).
Step 21:
Then sit back and watch the floor come together.
This would also look great as a bedhead or a studio wall.
Step 22:
And it is done.
and it has held up really well and still looks great.
