Introduction: DIY Peristaltic Pump
In this project we will have a look at peristaltic pumps and find out whether it makes sense to DIY our own version of it or whether we should just stick with the commercial buy option instead. Along the way we will create a stepper motor driver circuit and a suitable 3D print for our DIY version.
Step 1: Watch the Video!
The video gives you all the information you need to create your own peristaltic pump. During the next steps I will present you some additional information.
Step 2: Order the Components!
Here you can find a parts list with example seller (affiliate links):
Ebay:
1x Arduino Nano: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x NEMA17 Stepper Motor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x DRV8825 Stepper Motor Driver: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 100µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress:
1x Arduino Nano: https://s.click.aliexpress.com/e/_dULoNXh
1x NEMA17 Stepper Motor: https://s.click.aliexpress.com/e/_dXs7VYF
1x DRV8825 Stepper Motor Driver: https://s.click.aliexpress.com/e/_dShHOO3
1x 10kΩ Potentiometer: https://s.click.aliexpress.com/e/_dX83GAF
1x 100µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
Amazon.de:
1x Arduino Nano: http://amzn.to/2HrK4kY
1x NEMA17 Stepper Motor: http://amzn.to/2odkI1m
1x DRV8825 Stepper Motor Driver: http://amzn.to/2Hsa3sE
1x 10kΩ Potentiometer: http://amzn.to/2oiVsXV
1x 100µF Capacitor: http://amzn.to/2FbDNcx
Step 3: Build the Circuit!
Here you can find the schematic and code for the circuit. Feel free to use them as a reference.
Step 4: 3D Print the Pump!
As mentioned in the video, my design is basically a modification of an already existing design from Ralf. It is this one: https://www.thingiverse.com/thing:254956
Here you can download my 5 modified .stl files in order to 3D print them. Make sure to use ABS and an infill of 60%.
Step 5: Success!
You did it! You just built your own Peristaltic Pump!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
1 Person Made This Project!
- FranD9 made it!
15 Comments
Question 8 months ago
Hello,
thank you for this tutorial.
I don't understand the VCC part with the Stepper Drive Controller... Do we need absolutly the stepper motor Drive controller for this project ?
Currently, i have 0,6v without connecting the 12V to VCC steppe motor driver.
Can i connect 5v and not 12v to VCC ? And forget the Stepper Drive Controller ?
Thank for you answer
Question 1 year ago
Having some trouble creating the sketch you supplied. Any help would be greatly appreciated!
1 year ago
Can i get 5v from arduino 5v pin?
3 years ago
Can this pump handle carbonated liquids and still have an accurate output?
Question 3 years ago
Can I use PLA for this model?
4 years ago
Can someone explain me what the capacitor is for? It's for absorbing backward current?
so the nema got 5v directly from arduino? what if I want to connect 20 motor? how can I modify the circuit to have exxternal power source?
Reply 4 years ago
it protects the stepper motor driver from voltage spikes
Question 4 years ago
will the STL files print in the same size as in the DIY or Buy video?
I would like to control the stepper motor intermittently using 3 potentiometers:
1. Speed
2. time of rotation or number of steps
3. The dwell time
Please help me write the code.
Question 5 years ago
I am leveraging your code to produce a variable frequency output. The code works perfectly on at ATMega328 but I am having trouble porting it to the ATTiny85. Are you familiar with the ATTiny series of chips? Would you be willing to assist? My code:
long analogvalue;
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
void setup()
ADCSRA &= ~PS_128;
ADCSRA |= (1 << ADPS2); //ADC Prescaler of 128
TCCR0B = 0;
TCCR0B = bit (WGM02) | bit (CS00); //CTC mode, no prescaling
TCCR0A = 0;
TCCR0A = bit (COM0B0) | bit (COM0A0); // enable CTC and toggle OC0B/OC0A on compare match
pinMode (1, OUTPUT); // chip pin 7 // OC0B - Timer 0 "B"
pinMode (0, OUTPUT); // chip pin 8 // OC0A - Timer 0 "A"
pinMode (A1, INPUT);
} // end of setup
void loop() {
delay(100);
analogvalue = analogRead(A1);
analogvalue = map(analogvalue, 0, 1023, 200, 100000);
OCR0A = analogvalue;
Answer 5 years ago
To anyone interested in the answer to the above, please see:
http://www.avrfreaks.net/forum/attiny85-variable-frequency
Do the STL files already account for the shrinkage of ABS or did you select to print them a few percent larger in the slicer?
Answer 5 years ago
No, I did not enlarge the model with the slicer software. Everything should fit without modifications.
5 years ago
Aside from the price issue (no real issue for those of us who just like to build things). These pumps cause the tubing to see a lot of wear and tear from the roller process, thus they fail a lot and I'm not sure an ABS housing would stand up to the load either. As a hobby build it would be instructive but I'd make sure it had a drain tray under it if it were unattended.
5 years ago on Step 5
After adding prices of all of the components I got roughly something around 10+3+1.5+some small parts = ~15$. You added 3D printing costs as 5$ so in total it's around 20$ for 200ml/min pump.
Doesn't it have worse "value to price" factor comparing to cheaper pumps You mention on the beginning of Your video?
