Introduction: DIY Persistence of Vision
In This Project I Will Introduce You To Perspective Of Vision Or POV Display With A Few Supplies Such As Arduino And Hall Sensors To Make A Rotating Display Which Displays Anything You Like Such As Text,Time and Other Special Characters.
Step 1: Order the Parts
Here you can find a parts list with example sellers for your convenience (affiliate links)
Amazon.in
PCB : https://amzn.to/36BFP3z
1* Arduino Nano : https://amzn.to/3bIIsBv
1*Lithuim Charger Controller : https://amzn.to/36eUnpn
8* Blue Leds and 2* White and 1* Red : https://amzn.to/3ebnFYP
Step Up Module 2A : https://amzn.to/3e8Ok8s
150 Ohms Resistor : https://amzn.to/3gjy1aL
Lithium Polymer Battery : https://amzn.to/2WX6KDx
Dc Motor : https://amzn.to/36wMpIn
Hall Sensor : https://amzn.to/3gdRVUK
Neodymium Magnet : https://amzn.to/2A0ni4G
Banggood
PCB : https://bit.ly/2TyTpz6
1* Arduino Nano : https://bit.ly/3eheXIK
1*Lithuim Charger Controller : https://bit.ly/3grCE2S
8* Blue Leds and 2* White and 1* Red : https://bit.ly/2XrBFGW
Step Up Module 2A : https://bit.ly/2ZyfZvE
150 Ohms Resistor : https://bit.ly/2XveThM
Lithium Polymer Battery : https://bit.ly/3ghRBEx
Dc Motor : https://bit.ly/3cZcH8v
Hall Sensor : https://bit.ly/2XsjEbN
Neodymium Magnet : https://bit.ly/3cYlNT5
Spray Paint And Other Parts Are Optional.
Step 2: Create the PCB
Create A Custom Sized Through Hole PCB By Cutting It in the Dimensions Of 17 cm* 2.3 cm Feel Free To Smooth The Edges And Sides With Sandpaper and Give a Curvature Like Shape Towards The Ends. Spray Painting The PCB With Black Spray Paint Gives It a Glossy, Shiny And A Good Look When The Assembly Rotates.
Step 3: Build the Circuit
Use the here presented schematic and reference pictures to create the circuit.
I have Made Use Of a Boost Converter As Well To Boost The Battery Voltage Of 3.7 V To 5 V.
Step 4: Final PCB
The Final PCB Should Somewhat Resemble As In The Aforementioned Picture, The Shaft Which Connects To the PCB can Be Connected Through the Rings Which Are Permanently Attached With The Help of Super Glue Or Araldite .
Step 5: Upload the Code
The Code Can Be Uploaded To The Arduino After Selecting The Arduino And The Port, The Code For Display Text Is Editable And Any Text Can Be Written/Uploaded To The Board. For The Purpose Of This Instructable I Have Uploaded The Text Instructables.
Step 6: Success!
You did it! You just created your own POV Display!
