Introduction: DIY Planter
DIY Planter using buckets and rope
4 Dollar Tree Plastic Buckets with Handles(if you can find without handles, even better!)
Scissors
E6000 Permanent Craft Glue
Cotton Rope
Tape
Artificial Moss
Kraft Paper(optional)
Artificial Plant
Step 1: Remove Handles
Cut the handles off each basket.
Step 2: Glue Baskets Together
Glue two baskets together, connecting the base of the baskets.
Repeat this process with the remaining two baskets.
Glue both sets of baskets together, connecting the rim of the baskets.
Step 3: Let Dry
Let the glue dry overnight.
Step 4: Add Rope
Starting at the base, glue the rope around the basket and continue wrapping to the top. Use the same tension and keep the rope close to avoid open spaces.
Cut and seal the ends of the rope with tape.
Step 5: Add Plant
Place a plant inside the center of the top basket.
(Optional) Add Kraft paper around the plant.
Step 6: Cover With Moss
Cover the base of the plant with artificial moss and add the finished product to your home decor.
