Introduction: DIY - Planter Box
Christmas is just around the corner and my front-yard was looking like a small JUNGLE. So, before crack opening a cold one with the boys I planned to fix my front-yard
Step 1: Hardware Requirement
For this project we need:
  • Pallet Wood
Protective equipment like:
  • Face mask
  • Glasses
  • Gloves
  • Sanding Tool
  • Hammer
  • Measuring
  • Tape
  • Nails
  • Handsaw or Chop-saw
  • Knife
  • Pliers
  • Pencil and
  • Paint of your choice
Step 2: Dismantling the Pallet
Using 2 hammers I am going to dismantle the pallet. My aim is to reuse all the nails that are used in building this pallet.
Redwood and Cedar are in general the best option to building a raised garden box in terms of longevity because they are naturally rot-resistant and have been known to last for up to 20 years and they looks gorgeous.
Step 3: Measurement
Lets start by measuring the length, width and the height of the area where I am going to place the planter box.
Step 4: 3D Model
Based on the measurements, I am going to assemble the two small sides first.
After that, I am going to put together the two long sides and join them all together. Once all the sides are ready, I will paint the parallel planks gray, and the legs with black paint. After that, I am going to add the potting mix to the planter box and plant the agave plants to the box. Well, enough of talking, now lets get started.
Step 5: Sanding
Lets start the project by sanding the planks to give them a nice and smooth texture.
Step 6: Wood Cutting
After that, with my magical super fast hands, I am going to cut all the wooden blocks and keep them aside.
Step 7: Building the Box
Sides
As per the plan, I am assembling the two identical small sides first. The two legs which I am going to put on the sides are going to firmly hold the 3 inner planks together.
Front
Next, I am assembling the two longer sides. This planter box is not going to move from its position. So, there is no point of adding any planks to the bottom of the box.
Joining The Sides
Once all the sides are ready I am joining them all together. For a bit of extra support I am adding a metal bracket to hold the sides.
Step 8: Painting
Alright, thats all with the nails and the hammers.
In the next section I am going to paint the exterior of the box as per the plan. My partner came up with an idea of drawing borders between the wooden planks, and frankly speaking, with a bit of an extra effort the box now looks even more appealing.
Step 9: Lining the Box
Before pouring the soil into the box I am adding a liner to help maintain and prolong the life of the container.
Frankly speaking, lining can be something as simplistic as a black trash bag. These bags are an easy and cheap alternative to the ground liners. If the bag is too big or has a lot of extra length for your wooden planter, you can cut away the extra length with a scissors. Place the bag in the planter to check how much of the bag you need to eliminate.
Step 10: Adding Potting Mix
The pallet planter is almost ready. All I have to do now is to fill the planter box with soil. Remember, do not overfill it and make sure to keep the soil at least a couple of inches below the lining level.
Step 11: Planting Agave
And now to evenly plant the Agave plants I am placing few sticks to find the right spots.
And, thats it, to wrap it all up I am one by one removing the sticks and planting the Agave plants in the box.
Step 12:
This is another beautiful creation of the wooden pallet that is recycled into an excellent piece work.
So, lets ring the boys and crack open some cold ones.
Thanks again for checking my post. I hope it helps you. If you want to support me subscribe to my YouTube Channel (https://www.youtube.com/user/tarantula3)
Full Blog Post: https://diy-projects4u.blogspot.com/2019/12/diy-p...
Video: https://diy-projects4u.blogspot.com/2019/12/diy-p...
Thanks, ca again in my next tutorial.
