Introduction: DIY Polymer Clay Red Rose Candle Holder
About: I am a passionate industrial designer that loves to create all kind of things. I also studied some semesters of Robotics at the university. I love learning and teaching as well. If you have any questions about…
In this instructable you will learn how to make a pretty rose-shaped candle holder.
  1. Masking tape
  2. Paper sheet
  3. Scissors
  4. Pencil
  5. Rule
  6. Plastic wrap
  7. Candle
  8. Polymer clay
  9. Acrylic sheet
  10. Roller
  11. Cutter
Step 1:
Instructional Video :)
Step 2:
Draw the base circle of the candle and its height. Cut these pieces out of the sheet of paper.
Step 3:
Stick with masking tape the pieces cut in the previous step (as shown in the images)
Step 4:
Cover the candle with plastic wrap
Step 5:
Cut the polymer clay into small parts and create groups as shown in the images. Then mix each group created.
Step 6:
What I did in this step was to cut a small portion of each ball of polymer clay and combine it with another small portion of the one next to it, in order to create more shades of color.
Step 7:
Create cylinders of polymer clay with each color and flatten them with the roller
Step 8:
Join all the parts and flatten them with the roller
Step 9:
Combine some yellow with white, knead it into a cylinder shape, flatten it with the roller and join it to the bottom as shown in the images
Step 10:
Then cut it into two parts and add a bit of yellow to one of them.
Step 11:
Join both parts (leaving the yellow in the center) and flatten them with the roller
Step 12:
Now cover the top with red
Step 13:
Cut the piece into three equal parts and join them
Step 14:
Cover them with more red and again cut it into 3 equal parts
Step 15:
Join the parts and start kneading a little, giving a triangular shape
Step 16:
Cover with red polymer clay and cut pieces approx 3 or 4 mm wide
Step 17:
Those pieces that did not turn out very well when cut, I mixed them and with them I created the lower part of the candle holder.
Step 18:
Then what I did was flatten each petal a bit with the roller, stick it to the polymer clay base made in the previous step and finish shaping it with my fingers.
Step 19:
When the candle holder was the shape I wanted, I cut the plastic wrap and took out the candle. Then I carefully removed the plastic.
Step 20:
I put it in the oven for 30 minutes at the temperature suggested by the polymer clay supplier.
Step 21:
When it cooled down I put the candle inside it and enjoyed seeing it finished :)
